Thread started 29 Dec 2008 (Monday) 10:14
35mm f/1.4L filter help
saralee
Dec 29, 2008 10:14 |  #1
Can someone help me identify which UV filter would be suitable for my lens?
http://hvstar.net …Action=VIEWPROD​&ProdID=42 (external link)
http://hvstar.net …ction=VIEWPROD&​ProdID=237 (external link)
or a cheaper alternative:
http://hvstar.net …ction=VIEWPROD&​ProdID=851 (external link)
What's the difference between brass or alloy on the filter? Is the material referred to the mounting ring?
Thanks.
pixel_junkie
Dec 29, 2008 10:58 |  #2
saralee wrote in post #6962954 (external link)
Thanks.
All three work fine. Brass is the material the ring that holds the glass is made of. The difference b/n brass and alloy is that brass is heavier and feels more solid and is easier to get off your lens. I use a Hoya on my 35 and I like it. Never had a problem with it getting stuck.
Cheers
Website (external link) | Blog (external link)
Bill ­ Roberts
revolting peasant
Dec 29, 2008 12:10 |  #3
pixel_junkie is right, all three work fine.
My personal opinion would be to go for the B+W with the brass mount. Hoya's can be a bit of a pain to clean sometimes (streaking) which is why I prefer B+W.
You're almost certainly going to get people telling you not to use a filter at all, I'm not going to comment on that :)
cheers
BiLL
Double ­ Negative
*sniffles*
Dec 29, 2008 13:55 |  #4
Stick with Heliopan SH-PMC, B+W MRC or Hoya Pro1. I prefer the first two.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
731 views & 0 likes for this thread, 4 members have posted to it.
1052 guests, 175 members online
