Thread started 02 Jan 2009 (Friday) 07:22
Wine glasses with an etched logo
Jryan
Location: I've been asked that many times, as well what the ... is wrong with you?
Jan 02, 2009 07:22 |  #1
I'm sort of stuck here. I'm trying to photograph two wine glasses with an etched logo on the front and a different etched logo on the back. Person would prefer that they be empty (my first thought was to put wine/food coloring or something in them).
Anyway, I have at my disposal the gear in my sig, an efs 60mm macro, and a lightbox.
Any advice is greatly appreciated.
Thanks.
Canon 7D, 40D w/kit 28-135, Canon 24-105 f4L IS USM, Canon 70-200 f4L IS USM, Canon 17-55 f2.8 USM IS, Sigma 70-300mm f/4-5.6 DG APO, Canon 50 f1.4, Canon 60mm Macro, 580EXII, MR 14-EX, PS CS4
Josh Ryan
rrdjserv@earthlink.net
Jan 03, 2009 07:25 |  #2
Kind of difficult to take a picture of a glass and not see through it. Two possible suggestions. Can you aim your flash on the inside of the glass pointing toward the camera. That way it would light the front logo and perhaps darken the back logo. Second idea: Fill the glass with cherry Koolaid (or something color contrasting) then try to PS it out after the shot.
I don't believe either idea is acceptable, but it may work. Good luck.
--Rick
Sigma 500mm f/4.5, Canon EOS 7D, Canon T1i, Canon 300L f/4 IS, Canon 100mm macro, Tamron 17-50, Kenko extension tubes, Canon 580 Speedlite
--Rick
DigitalSpecialist
Jan 03, 2009 08:02 |  #3
Try using a dark colored or contrasting color behind the Wine Glasses. You might even want to shoot the glasses from an angle. So as to reflect off the insignia. Just my two cents!
JIM
EOS 630, 1N, 1DsMkII, and 5D/wgrip and some L glass.....
Jryan
Jan 03, 2009 23:01 as a reply to  @ DigitalSpecialist's post |  #4
Thanks, I'll experiment with those ideas.
Josh Ryan
milleker
Joined Feb 2006
Jan 06, 2009 22:44 |  #5
Kind of hard to explain, glasses on dark background, off to each side use white cards which you will hit with your light - this lights the glass from behind and no reflections/hot spots.
The dark background will give you enough separation that it should keep your etching much lighter (might need a bump in PS) and the white sides not only give you a place to project light from, but will give you a white edge in the glass.
If you shoot glass often I highly recommend Light Science and Magic as they have a wonderful whole chapter on lighting glassware.
---John Milleker Jr.--
Web Links: My Homepage (external link)
Photography Weblog (external link)Flickr (external link)Maryland POTN Meetup Thread (external link)Donate to POTN! (external link)http://www.johnmilleke​r.com/weblog (external link)
brecklundin
Jan 12, 2009 05:46 |  #6
here are some examples of what I suspect you are trying:
I actually started a thread about it to get suggestions...the comments I received in the thread were really helpful...here is a link in case it helps:
https://photography-on-the.net/forum/showthre​ad.php?t=535580 (there are a few more shots there too)
one crutch I also used is Live View at 5x or even 10x with spot metering on the cut portion (in your case etched) of the piece and manual focus to really get sharp detail of the pattern which also seems to move the pattern on the back side of the piece so out of focus it really does not interfere with the front side. I was specifically working with colorless glassware that day (often called "crystal" in the collector world even if the piece is not true lead crystal glassware) but the concepts port over to colored glassware perfectly.
I will reiterate something from my previous thread...getting good sharp shots will reveal every minor imperfection either in the surface of the piece or within the glass itself. These are not typically visible to the eye under normal conditions. So, you will likely want to spend some time cloning out the "nastiness"... ;)
Real men shoot Pentax because we're born with our own Canon's!!
{Ok...ok, some of use just have a PnS but it it always makes me happy! :D}
Pentax K5, K20D, Three Amigos (Pentax FA 31/1.8 Limited Silver, Pentax FA 43/1.9 Limited Silver, Pentax FA 77/1.8 Limited Silver), Pentax DA 35mm F2.8 Macro Limited, Sigma 24-60/2.8
brecklundin
Jan 12, 2009 05:48 |  #7
milleker wrote in post #7021070 (external link)
COOL....running to look into that book as I shot a LOT of glassware...thanks even if it's not my thread!!
While reviewing the book on Amazon and trying to understand the difference between the $45ish 5th edition and the $30ish paperback 3rd Ed. yet both published in the same year...??...I just ran across the flickr group dedicated to the book:
http://flickr.com/grou​ps/84897717@N00/ (external link)
A fast glance shows they are working on a 4th ed of the paperback version. And there are a ton of amazing shots there to try and figure out...
Jryan
Jan 15, 2009 08:59 as a reply to  @ brecklundin's post |  #8
Awesome, thanks for the advice!
Josh Ryan
3,097 views & 0 likes for this thread, 5 members have posted to it.
1404 guests, 162 members online
