Thread started 02 Jan 2009 (Friday) 09:20
5d MkII Hot Pixel Problem
silvias13
Jan 02, 2009 09:20 |  #1
Purchased my 5D MkII about a week ago. Everything was all good until yesterday where I spotted one hot pixel showing up on all my pictures and movies. I can actually see the red dot when I switch to live view on the lcd.
I tried doing the cleaning trick where you put the cap on the camera body. The trick worked! It got rid of that hot pixel and I don't see it in my photos anymore but I still see it when I shoot movies.vmad
Should I bring it back and exchange for another camera? Can or will this hot pixel pop up again in the future even though I get a new one? Does anyone else with a 5D MkII having this issue?
flickr (external link) | 500px (external link)
gjl711
"spouting off stupid things"
Jan 02, 2009 09:27 |  #2
If it's still within the exchange period, I'd swap it out. It's much easier to exchange poorly performing equipment than it is to work with Canon fixing the issue.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
silvias13
Jan 03, 2009 13:02 as a reply to  @ gjl711's post |  #3
Does anyone else with a 5D MkII having this issue with movie mode?
silvias13
Jan 15, 2009 08:41 as a reply to  @ silvias13's post |  #4
Update: I brought it back to Adorama and exchanged it. Let's hope the new one behaves...
JBF
Jan 15, 2009 09:21 |  #5
MOst digital camera will have hundreds of hot pixels. You usually don't see them unless you are shooting at ISO's over 1600 and long exposures of 5 seconds or more. If you are seeing them at low ISO's with regular shutter speeds of 1/60 or higher, I would exchange my camera. I read somewhere that Canon's acceptable hot pixel's per sensor is about .01%. Which means that if you are shooting a 5D Mark II and it has 21 megapixels your camera could have up to 210,000 hot pixels. You will never see most of them. 210,000 out of 21,000,000 is a very small amount. However if I ran the dead pixel test and my camera came back with 210,000 hot pixels, I would send it back. My original 5d at ISO 3200 and 1/30sec had 267 hot pixels. But I had to zoom in to 1600 percent to see most of them. Conclusion: If you are shooting and don't see them.....then don't worry about it. If you just have to know then download the software and pixel peep your sensor to death. Remember, shoot with the lens cap on and then start shooting long exposures with different ISO's
JBF
Canon 7D, Canon 1D Mark IV, Canon 24-105L f/4, Canon 35L 1.4, Canon 200L f/2.8, Canon 70-200L II IS f/2.8, Canon 300L f/2.8IS, 580ex Flash, 430ex Flash, 1.4X Converter. Bunch of other crap! I want the new 500mmL and the 200L f/2.0
iacas
Jan 15, 2009 23:46 |  #6
JBF wrote in post #7081949 (external link)
210k/21,000k is 1%.
0.01% is 2,100 pixels. Still sounds like a lot, but 210,000... yikes.
Erik J. Barzeski
[nslog.com (external link)], [erik.photoblog (external link)] - Please Visit and Vote
Gear: Canon 5D & 5DII with: 50/1.4 | 85/1.8 | 24-70/2.8L | 70-200/2.8L IS | 300/2.8L IS | EF 1.4x TC - Gitzo GM-5540, Gitzo 2530EX, RRS BH-55 LR, B2-Pro II [All Gear Listed at my Blog (external link)]
_Sim
Jan 20, 2009 11:03 |  #7
I ran into this problem too when I first received my 5DII and found the following fix online:
1. Remove lens, and place body cap on camera.
2. Select "Clean manually".
3. Leave it in this mode for 30-60 seconds.
4. Shut the camera off directly without doing anything else.
It did the trick for me... no more hot pixels. No idea why it worked though I've read a few theories.
I know you exchanged your camera so it's no longer a problem for you, but I thought I'd post it anyway because I was so pleasantly surprised that it worked!
(My) flickr (external link) & Gear
silvias13
Jan 20, 2009 11:20 as a reply to  @ _Sim's post |  #8
Yeah it did the trick and it worked for pictures but the major issue was that it still shows up in movie mode... Do you see it in your videos?
_Sim
Jan 20, 2009 11:22 |  #9
I've actually never tried video mode :oops:
I don't have much interest in it.
silvias13
Jan 20, 2009 11:30 as a reply to  @ _Sim's post |  #10
You should try it and see... I didn't get this camera for the video features either but I personally feel that after spending over $2700 on a camera I expect everything should work... I'm just glad it was still in the exchange period.:)
_Sim
Jan 20, 2009 11:39 |  #11
Definitely... exchanging it was a good move.
I know where you're coming from, but I have a slightly different perspective. I would have bought this camera even if it didn't have a video mode. I've tried all the features I care about, and have been pleased with everything. I personally don't care if there are any hot pixels in a mode I'll never use. I will take a look at it out of curiosity once I get some time though.
JBF
Jan 25, 2009 09:33 |  #12
iacas wrote in post #7087297 (external link)
210k/21,000k is 1%.
Ooops, screwed that one up. I do not have a Beautiful Mind.
Ran the dead pixel test on my 5D Mark II at different ISO's and here are the results:
ISO 100 = 1 hot pixel at 20 sec, 1 at 30 sec
ISO 400 = 1 hp at 5 sec, 7 at 20 sec, 7 at 30 sec
ISO 800 = 1 at 1sec, 6 at 5 sec, 15 at 20 sec, 41 at 30 sec
ISO 1600 = 2 at 1sec, 7 at 5 sec, 49 at 20 sec, 66 at 30 sec
ISO 3200 = 2 at 1/4, 6 at 1sec, 22 at 5sec, 78 at 20sec, 74 at 30sec
I looked at the 20 second shot at 3200 and the 30 second shot at 3200 and at 100% I could not see any of them, zoomed in at 200% I started to see some, but I only counted around 10, at 1600% I saw about 70% of them. I think this is pretty darn good for this camera. My original 5D had more hot pixels than this new 5D Mark II. And the hot pixels on the original 5D never showed up in print either.
JBF
JBF
Jan 26, 2009 19:48 |  #13
How good is the dead pixel test software? Is it accurate?
JBF
DarthVader
There is no such thing as Title Fairy ever
Jan 26, 2009 19:54 |  #14
What threshold did you pick/set ?. I use the dead pixel test software and the standard is 60.
Here is mine:
ISO 100, 10 secs = 1
ISO 400, 2 secs = 1, 20 secs = 33, 30 secs = 41
ISO 1600, 10 secs = 5
ISO 3200, 10 secs = 27, 30 secs = 117
John
JBF wrote in post #7194030 (external link)
Nikon/Fuji.
Gear is important but skills are very important :)
cornellsupreme
Jan 27, 2009 06:55 |  #15
silvias13 wrote in post #6987852 (external link)
Just received my 5D MKII yesterday and I'm having the same exact issue with a hot pixel on photos and videos. I did the cleaning steps and it disappeared on the photos, and helped a little with the video, but its still very noticeable (on video).
I read a post on FM and some users are claiming this happened when they upgraded to firmware 1.0.7. I upgraded to 1.0.7 as soon I as received the camera so I cant vouch if it was the upgraded FW or not.. What version are you guys on with this problem ?
10,764 views & 0 likes for this thread, 19 members have posted to it.
Latest registered member is finnianmarlowe
1325 guests, 176 members online
