Thread started 04 Jan 2009 (Sunday) 08:17
Running a noise program - RAW
habenero
Jan 04, 2009 08:17 |  #1
I am pretty new at the post stuff. I shot some raw photos in the ISO 1000 plus range. I have DPP and Neat Image. Can I work with the image in RAW or do I need to convert to JPEG for noise removal. I understand RAW is the best way to shoot as you have more to work with in post? Please offer some suggestions!
Randy
PixelMagic
Jan 04, 2009 08:23 |  #2
What RAW conversion software are you using?
habenero
Jan 04, 2009 08:24 as a reply to  @ PixelMagic's post |  #3
Hi. I have the Canon software that came with the camera.
Randy
PixelMagic
Jan 04, 2009 08:41 |  #4
You'd want to convert to TIFF format (16-bit preferably) before running your Noise Reduction.
If you intend to print your photos I'd suggest you do a test print before running NR because in most cases noise that's noticeable on a screen is invisible in a print.
habenero
Jan 04, 2009 08:45 as a reply to  @ PixelMagic's post |  #5
Would you do things like contrast, WB, saturation, horizons first in RAW then go to Noise or vice versa and sharpen last?
Randy
PixelMagic
Jan 04, 2009 08:50 |  #6
Everything that can be done in the RAW converter should be done there; then convert to TIFF and run NR. Then if needed resize your image and add your final sharpening.
habenero
Jan 04, 2009 09:19 as a reply to  @ PixelMagic's post |  #7
Thank you for the help!
Is DPP the best option or should I look at Lightroom?
Randy
René ­ Damkot
Jan 04, 2009 09:36 |  #8
Opinions vary about that :lol:
I have both, and prefer DPP for IQ, LR for workflow to web.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Delivery ­ Man
Jan 04, 2009 09:44 |  #9
FedkaTheConvict wrote in post #7000823 (external link)
I am in the same boat as Habenero, just getting started in post processing RAW images using DPP. Why do you suggest converting to TIFF as opposed to JPEG format? I assumed since the camera converts to JPEG that it was the best format to use for the finished product for viewing and printing.
5D MkIII gripped, 5D MkII gripped, G12, EF 24-70 f/2.8L, EF 70-200 f/2.8 L, EF 16-35 f/2.8L II USM, EF 50 f/1.4 USM, EF 50 f/2.5 Compact Macro, Sigma 50-500 f/4.5-6.3 DG OS, Canon 2x III Ext, 530EX II, 430EX II, Lowepro Rolling Computrekker AW, Fastpack 200, Think Tank Holster 50, Cotton Carrier, Manfrotto 190XPROB w/ 222Joystick head.
Website (external link)
Tony-S
Jan 04, 2009 09:54 |  #10
JPEG only gives you 8-bit color depth. TIFF can give you 16-bit color depth (which is far more than your display can render). There's a lot more info in a 16-bit image than in an 8-bit image.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
neil_r
Cream of the Proverbial Crop
Joined Jan 2003
Jan 04, 2009 10:01 |  #11
Nik define will work on your RAW mages
http://www.niksoftware​.com/dfine/en/entry.ph​p (external link)
Neil - © NHR Photography
bohdank
Jan 04, 2009 10:45 |  #12
It won't work on the RAW file directly. It still needs to be converted to something else.
tzalman
Fatal attraction.
Jan 04, 2009 16:02 |  #13
neil_r wrote in post #7001230 (external link)
Since the OP said he has DPP and Neat Image telling him about a Photoshop noise reduction plugin seems rather pointless.
Elie / אלי
tkbslc
Jan 04, 2009 16:17 |  #14
Wow, lots of confusing advice on this thread.
Just open your CR2 images in DPP and play with the 2 sliders on the NR/Lens tab. You can usually do quite nicely with those two. If those can't clean it up, export it as a HQ JPEG and run it through neatimage if you like.
One thing I would add is to not expect perfection at 100% view for a high ISO image. I would try to make it look acceptable at 50% view and then it will look great at almost any normal print sizes (like up to 11x14")
Taylor
EOS Rp | iPhone 11 Pro Max
Titus213
Jan 04, 2009 19:27 |  #15
If you do not have the Adobe plug-in you'll have to run the batch version. It will only open tiff, bmp, or jpg. Of those tiff would be preferred.
Dave
Perspiring photographer.
1,368 views & 0 likes for this thread, 10 members have posted to it.
638 guests, 120 members online
