Thread started 16 Mar 2005 (Wednesday) 11:09
canon 100-400 f4
kszczes
Mar 16, 2005 11:09 |  #1
Due to the push pull design of the canon 100-400 F4 IS does this cause more dust to collect on the sensor of a DSLR.
timmyquest
Joined Dec 2003
Mar 16, 2005 11:13 |  #2
You will encounter people who claim that the lens is more prone to dust because it is being sucked into the crevices of the lens while zooming the lens out. Personally i think it's a load of crap...but then i've never owned the lens.
In either case, the lens doesn’t put your camera in any more harm then any other lens...
Capturing life a fraction of a second at a time
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 16, 2005 11:43 |  #3
I solve this problem buy not pumping the lens in and out while under my sofa... ;)
Really I've never found it to be a problem.. but I don't shoot in areas filled with dust bunnies at eye level often.
CDS' HOT LINKS
robertwgross
Joined Nov 2002
Mar 16, 2005 11:44 as a reply to  @ timmyquest's post |  #4
I guess we are discussing the Canon EF 100-400mm f/4.5 to 5.6 L IS lens.
We might have a discussion about whether the push-pull design will get dust into the lens structure. However, I don't think that is going to affect dust getting onto the camera's main image sensor, which is behind the shutter.
---Bob Gross---
timmyquest
Joined Dec 2003
Mar 16, 2005 12:49 |  #5
Or more importantly...behind the rear element of the lens.
BoySpot
Joined Feb 2004
Mar 16, 2005 12:52 as a reply to  @ robertwgross's post |  #6
I read an awful lot of comments about the pumping of dust. Some of it sounded like people justifying why they don't like this way of zooming. I wondered about it because I was getting ready to buy it. The thing is, if it is going to pump dust, it is going to bring it into the lens, not into the sensor which has a nice element at the back of the lens in the way. I may be wrong (and often am) but I think it is a red herring. By the way, I eventually bought the lens and love it.
CoolToolGuy
Boosting Ruler Sales
Joined Aug 2003
Mar 16, 2005 12:57 as a reply to  @ timmyquest's post |  #7
Push-Pull, Shmush-pull - any lens that expands and contracts is susceptible to inhaling dust, regardless of how it is actuated. I think this is a legend that grew some legs.
I do think it is time for Canon to update this lens, and hopefully they will do away with the push-pull when they do. In the meantime, don't get to concerned about the dust issue - if you like it, get it.
Have Fun,
Rick
My Gear list
RTMiller
Joined Dec 2004
Mar 16, 2005 13:07 as a reply to  @ CoolToolGuy's post |  #8
I have the 100-400 and never seem to have any problems.
When I push, it sucks the dust in. When I pull, it blows the dust out. The trick is to remember that for every push there must be an equal and opposite pull. This final pull not only helps expunge the dust, it makes the lense shorter and therefore easier to stow away.
Todd
www.PHOTODDGRAPHY.com (external link)
Equipment List
Everyone is beautiful if you squint.
Jim_T
Joined Nov 2003
Mar 16, 2005 13:20 as a reply to  @ RTMiller's post |  #9
I agree... If a lens can be extended, it's prone to sucking in dust.. It doesn't matter if you extend it by pulling it out directly, or twisting a ring.
I have one completely unscientific and unproven observation that I've noticed with the lens...
I was getting a considerable amount of dust on my sensor prior to purchasing my 100-400.. After I started using the lens, it seems I don't have nerar as much problem with sensor dust..
Could the air movement caused by the lens be cleaing out the mirror/shutter area of the camera :)
Parson
Mar 16, 2005 13:25 |  #10
I'be been around photography long enough to remember when a "one-touch zoom" was the latest and greatest in zoom techonology. It was hailed as a great advance over the "two-touch" zoom that required you to zoom with one ring and focus with the other. The advent of autofocus pretty well negated the concept since a two-touch zoom could still be controlled with one ring while the camera controlled the focus. I've used both for over 40 years and both are just about as likely to pull dust into the lens. If the lens is constructed properly, as is the 100-400, the dust problem is minimal and will not exagerate the likelyhood of dust on the sensor. They are remote from each other and mutually sealed from exposure to one another.
Just as a side comment, if you're considering the 100-400 you can't go wrong! I've used most major types of zooms - Nikon 80-200, old Vivitar one-touch zooms, the Sigma 50-500 and 120-300, Tokina 80-200 AT-X Pro - you name it, I've probably used it or something very similar to it. You will not beat the 100-400L! It focuses fast, it's quiet and sharp as the proverbial tack. I personally love the push-pull (one-touch) construction and find it much faster than a twist ring to zoom.
Hope this helps.
Dave H.
David H.
Canon 20D; BG-E2 grip; 17-85 EF-S; 100-400L; 580 EX
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 16, 2005 13:44 |  #11
Bob and Timmy,
the 100-400mm rear lens element is not fixed,. it too moves front to back during zooming,. and is not in any way sealed,. there is space around the rear element which dust can and will get around and into the camera body,. at ehich point with air movement possible and in fact likely ,. dust can and will find it's way around a shutter as well.
However,. Like CoolToolGuy says,. this is true of most zooms no matter what the method used to zoom,. This coupled with the fact that one must get dust into the lens beofre it can be pushed into the camera.. makes this lens no different from most zooms as far as dust potential is concerned, despite it's push pull design.
There are some Zooms that have a fixed sealed rear element,. like Canon's EF 70-200mm f/2.8 IS (and perhaps Timmy's non IS?) ... but this is not "the norm" these are Canons weather sealed lenses.
CDS' HOT LINKS
johneo
Joined Aug 2003
Mar 16, 2005 16:43 |  #12
I don't notice any more dust using the 100-400 L lens but that might be because I only use it in an environmentaly sealed clean room and only when I'm wearing a clean suit. Kind of limits what I can shoot and I have yet to be able to use the 400 end but at least I don't have to worry about dust.
Don't worry about it! You'll get no more dust with that lens than any other ... it's a great lens!
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
40mm pancake
neil_r
Cream of the Proverbial Crop
Joined Jan 2003
Mar 16, 2005 16:50 as a reply to  @ johneo's post |  #13
Why did I waste that money on a rocket blower, all I had to do was zoom my lens faster.... Oh well you live and learn.
N
Neil - © NHR Photography
RJSorensen
Joined Sep 2004
Mar 16, 2005 17:33 |  #14
The copper hill kit cleans the sensor . . . shoot away and don't worry about what will happen anyway. I love my 100-400, btw.
"With Some Practice . . . I Am Able to Believe Six Impossible Things Before Breakfast!"
5D, 20D, EF 50 f/1.4, EF 16-35 L, EF-S 17-85, EF 24-70 L, EF 100-400 L, 1.4 TC II, Tubes, 550 EX, 580 EX.
TammieO
Mar 16, 2005 20:40 |  #15
I really like the push/pull design and I haven't had to clean my sensor yet.
Tammie
1DMkII
4,029 views & 0 likes for this thread, 22 members have posted to it.
canon 100-400 f4
1607 guests, 114 members online
