Docthomas wrote in post #7011472
same pic made to look as close to identical as possible between the monitors.
What application are you viewing the image in?
You should get the monitors to match, not adjust the image to the monitor.
IMO the first is okay, second is over saturated, but the difference is small enough to be a matter of taste.
Noticed I'm having to "push" that monitor at 100% brightness to get it equal may have something to do with washed out colors?
If that old screen is at about 100% brightness, what luminance do you get?
My laptop is a bit older then your screen, yet my calibration software tells me to set luminance lower then 100%. Luminance is lower then I'd like then (about 8osomething Cd^2), yet if I pot it higher, the blacks go too light.
It's a case of the backlight being on the way out I suppose.
I'd try to set the luminance as indicated by the calibration software. If one screen is way too dark then, it might be time to buy another...
Also, be aware that if you want to match displays, the only way to do it is to bring the best display down to match the worst!
Finally: Make sure your graphics card has a dual LUT (one for each screen), otherwise, the calibration software will load the LUT with the correct data for the last calibration, so the screen you calibrated first will not be calibrated anymore...
(pretty easy to find out, by calibrating display one, evaluate the profile (I think iOne Display offers the feature), calibrate display 2, evaluate both profiles. If the first shifted (big time probably in that case) then you cannot calibrate 2 monitors on that card. A 2nd video card would be needed.
http://www.northlight-images.co.uk …_monitor_calibration.html
