I am by no means a expert at color management. However, I have managed with the help of POTN members to get my Samsung 245T LCD calibrated pretty good and my prints match my monitor perfect. So I thought it may be useful to post the process with screen shots to help others.
(I had to keep the post to 8 pictures so some images had to be 1500 long, sorry.)
1. First start of by launching the software, I am using Version 3.6.1 on Windows XP. Graphics card is a 6600GT using DVI hookup.
2. I always choose to do a advanced setup, select whatever works best for you then click the next arrow.
3. Choose LCD, click next arrow.
4. I choose Medium White 6500K, Gamma 2.2, and check to do a ambient light test, click next arrow.
![]() | Byte size: ZERO | Content warning: NOT AN IMAGE |
5. Mount the ambient light head onto the calibrator as shown, click the calibrate button.
6. Once it performs its calibration it will give you a confirmation then click next arrow.
7. Face the calibrator out like shown in picture and click measure. The goal is to have the black slider in the middle of the green. If I adjusted my illuminance so it was in the middle the the color temp would drop so I tried to pic a happy medium. Once your done click next arrow. Also note that I have special 5000k Craft CFL bulbs for lighting in the room.
8. Remove the ambient light head and place on screen as shown. Make sure it is up against the screen, mine I have to press lightly on it. You may also want to place the calibrator off to the side instead of in the middle of the screen. It makes it hard to do adjustments reading through a calibrator and when you adjust the controls the pop up box from lcd may throw off the calibrator? Click the next arrow.
9. Set the contrast on the monitor to 100% as shown, then click start. The boxes will blink around trying to center the calibrator on the screen, do not move the calibrator or it may fail the test. Once the slider is in the middle click stop. Sometimes you have to move the mouse around for a second or two for it to appear.
10. On my monitor I have independent RGB controls so I select that option and click start.
11. Make your changes to the monitor until the sliders are in the middle then click stop.
12. After your done with RGB calibration it will kick you back to that screen, just click next arrow.
13. Now it will go through a bunch of colors for 2-7 minutes, keep calibrator stuck to screen and do not move around.
14. After its all done this screen will pop up, click next arrow.
15. The next screen will pop up asking you to save your ICC profile, click OK.
16. Last step for me is to verify that the ICC profile saved and is selected. Go to your desktop and Right click > Properties Tab > Advance > Color Management tab.
All monitors will be different, especial with different ambient lighting. In the end my monitor was set to:
Contrast 93
Brightness 0
Red 48
Green 50
Blue 48
Gamma +0.3
Saturation all colors set to 50
Hue all colors set to 50
MPA Off
Hope this helps...Jeff
