At LensesForHire we have a Canon TS-E 90mm tilt-shift lens. Amazing bit of kit, and if I live to be 900 I might one day start to understand how to use it. Or maybe 900 years isn't enough.
Anyway, one of our customers suggested getting it modified so that the tilt axis and the shift axis are parallel, rather than perpendicular as it is supplied by Canon. His reasoning was that this would make it more suitable for product photography, whereas having the tilt and shift axes perpendicular was more appropriate for architectural photography - for which you'd probably prefer to use the TS-E 24mm anyway.
Apparently it's a simple modification and the lens is explicitly designed to allow it.
So:
- Can anyone confirm that the customer's reasoning is correct? (Regarding both what the modification would achieve, and the likely use of the lens?)
- If I did it myself, would I invalidate the warranty? Or should I just send it off to Canon?
- And when I get the TS-E 45mm, should that be modified too? (What would people use that lens for?)
Any help appreciated.
