Thread started 08 Jan 2009 (Thursday) 13:19
5D sensor cleaning with E2
Jan 08, 2009 13:19 |  #1
I just cleaned my 5D with a sensor wand with E2 solution. I got all the dust off but I can see streaks on the sensor, is this normal? I clean my 30D with regular eclipse and pec pads and they leave no streaks at all.
Hermes
Jan 08, 2009 13:20 |  #2
Is this the first time you've cleaned the 5D?
Did you follow the specific instructions for E2 (different technique to regular eclipse fluid)?
gjl711
Jan 08, 2009 13:23 |  #3
E2 solution has isopropyl alcohol which means that there is a little water as well. I have been using the E2 since my XTi days and have found that after wet cleaning thoroughly, a final pass with a dry pec pad and sensor wand lightly gets rid of any streaks.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
anglefire
Gallery: 193 photos
Jan 08, 2009 13:23 |  #4
I've used the original eclipse on my 5D and has been pretty good - no streaks - but the last time I cleaned it with the same stuff (I'm about out now) I had really bad streaks at the top and bottom of the sensor and corners.
I've since done it again and is better - but still not perfect. I need to get some more swabs as well. :(
Mark
My Website (external link)
Jan 08, 2009 13:26 as a reply to  @ anglefire's post |  #5
I'm afraid to use regular eclipse and pec pads on my 5D, I have 2 sensor wands left with E2 and would rather save them for another clean later this year.
blueM
"I am the Prince of Dorkness"
Jan 08, 2009 16:47 |  #6
I usually notice some streaking if I've put a bit too much solution on the pad. Less solution is better. Helps to wait 30 seconds to let some evaporate before swabbing
Kevin
1,081 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is josetide
1048 guests, 171 members online
