I found this while surfing around
http://www.lumiquest.com/products/fxtra.htm![]()
Palladium Goldmember 3,905 posts Likes: 2 Joined Dec 2005 Location: Not the Left Coast but the Right Coast - USA More info | Jan 08, 2009 20:34 | #1 I found this while surfing around The FXtra is a compact gel holder that facilitates a quick installation and removal of colored gels. Eight Rosco gels are included: CTO, ½ CTO, ¼ CTO, Plus Green, ½ Plus Green, Sky Blue, Canary Yellow and Fire Red in the integrated storage pouch. FXtra is sized to use with most popular flashes and the gel pocket accommodates both Rosco and Lee gel samples.
johnz Senior Member 529 posts Joined Sep 2006 Location: Tampere, Finland More info | Jan 09, 2009 07:22 | #2 Not too different from this. But might be better! - Tuomas Gustafsson
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | Jan 09, 2009 07:26 | #3 That's actually pretty handy. I don't use filters that often though. Did you lose Digital Photo Professional (DPP)? Get it here
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | Jan 09, 2009 07:55 | #4 I have the FX, which takes larger gels. I like it, although I do not use it too often. I find it handier than trying to attach loose gels to the flash. Doc Klepper in the USA
m3rdpwr Goldmember 1,332 posts Joined Jun 2007 More info | Jan 09, 2009 09:33 | #5 rklepper wrote in post #7038182 I have the FX, which takes larger gels. I like it, although I do not use it too often. I find it handier than trying to attach loose gels to the flash. Not to mention you loose a stop of light because of its front diffuser.
Moonjo Senior Member 401 posts Joined Jun 2007 Location: Rocky Mountains More info | Might want to take a look at the these posts... https://photography-on-the.net …hread.php?t=523186&page=6 EOS R5 BG-R10 | EOS R5 | Canon RF70-200 f/2.8L IS | Canon RF24-70mm f/2.8LIS | Canon EF100mm f/2.8LIS | Canon EF135mm f/2.0L | Canon EF85mm f/1.2L II | Canon EF24-105 f/4.0L IS | 580EX II.... and other lighting stuff
| Latest registered member is semonsters 1025 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
