My question is, what zoom should I set the flash to? I am not using a shoot through if it makes a difference.
Thanks, Dave
bmynbr Senior Member 729 posts Likes: 1 Joined Jul 2006 Location: Surrey BC Canada More info | Jan 09, 2009 19:59 | #1 My question is, what zoom should I set the flash to? I am not using a shoot through if it makes a difference. Canon 7d, 50 f1.8, Canon 17-85is usm, 58mm hoya cpl, 67mm b&w slim cpl, Manfrotto 190 tripod with 486rc2 ball head, Canon efs 10-22, 580exII, cybersyncs, Canon 70-200 f4L
Jan 09, 2009 20:20 | #2 I would gather that the widest angle would give you the best coverage through the umbrella but shooting at a longer flash focal distance would just mean the flash is contained more to the middle w/ less coverage www.vividemotionphotography.com
F4Cyborg Senior Member 952 posts Joined Dec 2008 More info | Jan 09, 2009 23:11 | #3 Permanent banI pop 2 550's into a umbrella all the time. One will work fine. To find the best setting for you flash, set everything up as you are going to use it. Point it at a shaded wall step back and take a shot ( from an angle to minimize the flare). You will be able to see the flash in the umbrella zoom in or out till you almost fill the Umbrella. You can also move the umbrella in the bracket. That way you almost fill it without spilling over. Cyborg: part Man, part Machine (the machine gives a hoot!)
JohnTheMacGeek Mostly Lurking 15 posts Joined Oct 2008 More info | Jan 10, 2009 00:34 | #4 F4 is right. Another thing to consider is making sure you don't have the 580 too close to the umbrella. What I mean is when you mount the umbrella to the lightstand, don't push it through very far. Do some testing by adjusting the distance between the 580 and umbrella and you'll see what I mean. Canon EOS 40D | BG-E2N Battery Grip | EF 24-70 f/2.8L | Canon 580EX II
Lotto Goldmember 2,750 posts Likes: 192 Joined Mar 2005 Location: Southern California More info | Jan 10, 2009 03:35 | #5 @ 24mm zoom without the wild angle diffuser works best for me. 5D, 24-105L, 70-200L IS, 85mm Art, Godox
agedbriar Goldmember 2,657 posts Likes: 398 Joined Jan 2007 Location: Slovenia More info | Jan 10, 2009 13:30 | #6 Lotto wrote in post #7044495 @ 24mm zoom without the wild angle diffuser works best for me. I'm a tele fan too
StuartLeslie Senior Member 611 posts Joined Sep 2008 Location: New York More info | Do some test shots. I find that I get softer shadows on 24mm but 105mm produces a hotter/sharper light. Similar results with shooting through- but even softer and more uniform shadows. I end up manually adusting zoom on flash pretty regularly now depending on what i am after. Gear: Canon 5D III, 5D and 7D | 300 f/2.8L IS | 70-200 f/2.8L IS | 85 f/1.8 | 17-55 f/2.8 [COLOR=navy]| 24-105 f/4L | 10-22 | Zeiss 35 f/2 | TS-E 24II | Alienbees
| Latest registered member is Marcsaa 652 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
