Which background color is the best for photoshop. Basically to select it and replace it with another image. In case I am unclear, like the special effects green or like the weather man.
Pmolan Senior Member 521 posts Joined Nov 2008 Location: New Jersey More info | Jan 10, 2009 15:10 | #1 Which background color is the best for photoshop. Basically to select it and replace it with another image. In case I am unclear, like the special effects green or like the weather man. EOS 50D | 17-55 f/2.8 IS | 70-200 f/2.8 IS L | 100mm f/2.8 macro | 580EX | 430 EX | 430 EZ | Team Buff!!
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Jan 10, 2009 15:16 | #2 |
JohnE Goldmember 1,025 posts Likes: 1 Joined May 2006 Location: Amarillo, TX More info | Jan 10, 2009 15:17 | #3 A solid background color is good (like a white bed sheet evenly lit), if you're going to replace it. John Elser
Jan 10, 2009 16:14 | #4 Most likely portraits of my kids. I just wanted to play around with backgrounds. Is there a specific reason of the Green/Blue background? Is that easier to select? EOS 50D | 17-55 f/2.8 IS | 70-200 f/2.8 IS L | 100mm f/2.8 macro | 580EX | 430 EX | 430 EZ | Team Buff!!
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Jan 10, 2009 16:21 | #5 You're better off using a white background because green/blue screens tend to bleed unless they are properly lit. If you have adequate lighting (strobes, etc) so you can light the blue/green screen to separate it from the subject then you'll be fine but other use a white backdrop.
Jan 10, 2009 16:40 | #6 There's nothing cheaper than a white sheet! EOS 50D | 17-55 f/2.8 IS | 70-200 f/2.8 IS L | 100mm f/2.8 macro | 580EX | 430 EX | 430 EZ | Team Buff!!
Jan 10, 2009 16:50 | #7 Does anyone know if there is a site that provides free digital backdrops? EOS 50D | 17-55 f/2.8 IS | 70-200 f/2.8 IS L | 100mm f/2.8 macro | 580EX | 430 EX | 430 EZ | Team Buff!!
Dooms_day Senior Member 509 posts Joined Jan 2009 Location: Maryland, USA More info | Jan 11, 2009 14:24 | #8 the green/blue screen backdrops are mostly for video production because it provides a completely separate color(s) for video mixing hardware to take and remove almost instantly, in a high quality image however, you want a backdrop of white or black, depending on the color of your background you plan to add because the green and blue will kinda blend in with the hair of the subject, or other soft edges Canon EOS-1D mk ii + 70-200 4.0 USM L + Sigma 28-70mm 2.8-4 + Nifty 50
kirkt Cream of the Crop More info | Jan 12, 2009 11:05 | #9 For keying of the background make sure you choose a color that is not going to interfere with colors in your subject and make sure to light the background evenly so that shadows from your subject, etc., do not mask or interfere with the separation between subject and background. Kirk
davidahn Member 50 posts Joined Apr 2009 Location: Apple Valley, CA More info | Jun 01, 2009 02:45 | #10 If you plan on adding/blending digital backgrounds into the photo, I've seen gray recommended due to the ease of blending the shadows into the new background. Gear: 5D Mark II; 24-105 f/4L IS, Sigma 50mm f/1.4, 70-200 f/4L IS, 85mm f/1.8, 100mm f/2.0, Sigma 15mm f/2.8 fisheye. Coming soon: 7D, 2nd Sigma 50mm f/1.4. Outgoing & for sale: 24-70 f/2.8L.
| Latest registered member is Frankie Frankenberry 1712 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
