I picked up a new 1D3 10 days ago and received a new 24/1.4L in the post yesterday. The date code for the lens indicates it was manufactured over a year ago, so I'm not sure where it's been all this time.
Anyway, my initial test was just to poke the lens at things in the garden and fire off some random shots to see how sharp my wonderful new "L" prime was. The IQ was appaling - just rubbish. I've had a go at fiddling around with microfocus adjustment but I feel I'm getting nowhere. Sometimes, especially very close up (18" or less), it seems like maybe +5 will do the trick, but even moving to only 3' away it seems like I need +20 or maybe even more.
Test calibration, adjusting MFA by just +1 from one shot to the next yields an inconsistency in results that I find alarming. The softness in the images doesn't even look like regular poor focus, there is some unpleasant roughness to the poor IQ, but it varies at random. It looks like it might be camera shake, but at 1/1000?
I've uploaded an ALBUM
of 100% centre crops with microfocus adjustment from +10 to +20. I'd be grateful for any opinions on the IQ. These were shot raw and cropped and converted to JPEG in DPP with standard picture style and sharpening set to 3. Apart from click WB there are no other edits. EXIF is....
24mm, f/1.4, 1/1000, 400 ISO.
Here's the setup. I know the tripod is not 100% rock solid, given that one leg is on carpet, but I think that with a shutter speed of 1/1000 the setup is more than adequate. I didn't use MLU or a remote/timer release, but quite honestly, if that's what it takes in order to get a sharp image at 24mm and 1/1000 then you can kiss goodbye to handheld photography.
![]() | HTTP response: 404 | MIME changed to 'image/png' | Byte size: ZERO |
Sample image at +13 on the MFA. Focus was with centre point only and no expansion points and centred over the 24 and the L ...
Same again at +14. How can this one be so good, while far from great, when the previous one is so dire?
I originally bought a 28/1.8 but thought the softness was abysmal at apertures wider than f/2.5, so I laid out the extra cash for the 24/1.4L. What I am seeing with these images, despite constant lighting and a consistent exposure (EXIF) that the image brightness is altering from one shot to the next and sometimes there are strong signs of flare/CA and decreased contrast.
Look at the contrast difference between these two images, the first at +17 MFA and the second at +18 MFA. The latter image is terrible....
Could there be something loose in the lens that is making results so variable? I'm not sure whether to return it or send it to Canon, but I'm not happy with this performance at all.
I guess I need to perform a similar test with other lenses and bodies, to see if I can nail the culprit, but this sure looks like a major lens issue to me. Thoughts?
