Thread started 13 Jan 2009 (Tuesday) 05:31
Bought Spyder 3 Pro... Now What?
funhouse69
Jan 13, 2009 05:31 |  #1
Hey everyone - I couldn't think of a better place than here for me to post this. I've noticed some huge differences in the way my photos look on various monitors. I know that this is to be expected but some of them look a little over exposed on several systems at home and at work but not on the system I processed them on (I shoot RAW and process through DPP).
With this in mind I bought a Spyder 3 Pro and did the "Calibration" on 2 of my LCD's and one Laptop. I will say that when it was done and looking at the before / after in the Spyder Software there was a very noticeable difference.
Since I can't seem to find any additional documentation I'm curious how this actually works once I calibrate the monitor. Am I correct in assuming that this "Calibration" is now applied through all of your applications as long as the software is running? If this is the case why don't I see any visible difference when I disable to application in my system tray?
I feel that my images look better / more consistent but this could just be my mind playing tricks on me.
I'd like to hear from some people that have experience with this.
Thanks in advance.
My Online Gallery (external link)
>>> My Gear List / Feedback <<<
For Sale LowePro Super Trekker
iacas
Jan 13, 2009 16:20 |  #2
I don't think you need to keep running the software. You set each computer to use their calibrated profile and then... that's it.
Granted, I'm on a Mac here - I ran it on all my computers, chose the profile it created for each, and that's that - but I doubt you have to keep running it... someone with Windows experience re: monitor profiles can tell you more.
Erik J. Barzeski
[nslog.com (external link)], [erik.photoblog (external link)] - Please Visit and Vote
Gear: Canon 5D & 5DII with: 50/1.4 | 85/1.8 | 24-70/2.8L | 70-200/2.8L IS | 300/2.8L IS | EF 1.4x TC - Gitzo GM-5540, Gitzo 2530EX, RRS BH-55 LR, B2-Pro II [All Gear Listed at my Blog (external link)]
funhouse69
Jan 13, 2009 16:38 |  #3
I did notice when I rebooted my computer a little while ago that the color changed on the monitor when the Spyder Application Loaded.
The biggest bummer is that I won't be able to calibrate my Dual Head Monitor System. The Release Notes say that unless I have two different video cards (which I don't) then a single profile will be applied to both monitors and that is what I don't want as I can see a noticeable difference between the two monitors :-(
snails
"I used the last of it to tip the strippers."
Jan 13, 2009 17:20 |  #4
funhouse69 wrote in post #7069454 (external link)
That is when you use the spyder to manually adjust the other monitor's internal settings.
Canon EOS 7D EOS 5D Mark II EOS 40D PowerShot G10 | Canon EF 24-105mm f/4L IS USM EF 100mm f/2.8L Macro IS USM EF 50mm f/1.4 USM EF 16-35mm f/2.8L II USM EF 70-200mm f/2.8L IS USM EF-S 18-55mm f/3.5-5.6 | Sigma 24-70mm f/2.8 EX | Canon Speedlite 270 EX Speedlite 430 EX | Sigma EF 500 DG Super
doghouse_94545
Jan 13, 2009 17:38 |  #5
just sent mine back to BnH, what a headache it was with this software, after calibration was finished, the blue looked like violent and pink look like magentas, in order to get back to normal i had to reformat my HD, i tried all kind of changes but no luck!! after refomatting 4 times i was pretty fustrated!!! kinda suck that the manufacture don't have a live tech support line, i email back and forth and finally they told the sensor might be defective!! oh well!!! i went ahead order the Elite hopefully it will work!! wish me luck!!lol.....
5D MKII, 5D, 40D, 3- 580ex II, 3 Gemini 500r studio light, Sekonic L358, ExpoDisc, 4-Pocket Wizard Flex TT5, 4-Pocket Wizard Plus II,70-200mm f/2.8L IS, 24-70mm f/2.8L, 85mm f/1.2L, 100mm f/2.8L IS macro, 16-35mm f/2.8L, 15mm f/2.8 Fisheye,50mm f/1.8, 1.4x EF Extender II, 2x EF Extender II
funhouse69
Jan 13, 2009 17:56 |  #6
I admit I was very hesitent to order the Spyder wben I saw B&H wouldn't take it back unless device was defective. Usually not a good sign and a high return rate item
CanuckBassist
Jan 13, 2009 18:00 |  #7
funhouse69 wrote in post #7069997 (external link)
I think it's because people can just calibrate their monitor and then try to return the item to get a free calibration.
bohdank
Jan 13, 2009 18:33 |  #8
Exactly.
btw... the Elite uses the same hardware device as the Pro. I have no idea why you would buy the Elite ?
iacas
Jan 13, 2009 18:49 |  #9
bohdank wrote in post #7070265 (external link)
Exactly.
Different software. It allows you to change more settings... And it's $99 to upgrade if you want to do it later - which I consider a ripoff.
Erik J. Barzeski
doghouse_94545
Jan 13, 2009 18:55 |  #10
iacas wrote in post #7070390 (external link)
i like the more setting option that's why and also it can be use to calibrate tv too
bohdank
Jan 13, 2009 20:24 |  #11
Would you know which settings are in addition. I looked at it when I was buying the Pro and couldn't see any use, in my case for the Elite.
funhouse69
Jan 13, 2009 23:02 |  #12
I have to say it took a little time but I was able to calibrate my two 19" Lacie Electron Blue Monitors Manually. I have them connected "Dual Head" to my main editing system.
I had to run to work but I did a quick test and reprocessed an image using the new settings and I think it made a huge difference. Here's the before / after...
1. Before
IMAGE: http://funhouse69.smugmug.com/photos/448433849_DLdfV-L.jpg
2. After
IMAGE: http://funhouse69.smugmug.com/photos/454545083_2Ss5C-L.jpg
René ­ Damkot
Jan 14, 2009 05:14 |  #13
One dual head video card should also work (if your version of the spyder does dual monitor: not sure there)
http://www.northlight-images.co.uk …_monitor_calibr​ation.html (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
funhouse69
Jan 14, 2009 05:34 |  #14
In the release notes it said something about not being able to calibrate dual head monitors "If the monitors are connected to a single video card" this is due to an issue with Windows and not with the application itself. If however you have two different video cards (which I do not) then it will work.
The software DID detect them both and allowed me to go through and tweak them equally but I believe it is only using the last profile and not both of them. Since I use my second monitor for my editing then I made sure that was the one I did last.
I think that I managed to manually tweak them to the point that I am happy with the results so far. I will see how it goes and might consider getting another video card at some point.
[shingo]
Jan 14, 2009 10:45 |  #15
I'm using windows 7 and I can load different profile for each monitor with a single video card.
Which os are you using?
4,067 views & 0 likes for this thread, 8 members have posted to it.
913 guests, 109 members online
