Thread started 15 Jan 2009 (Thursday) 02:49
EF 400mm L IS F/2.8 Collar is very stiff
gazcoyle
Joined Feb 2006
Jan 15, 2009 02:49 |  #1
Hi Guys
Unlike many smaller lenses the tripod collar on my EF 400mm L IS F/2.8 cant be removed for cleaning or lubricating the rollers or the plastic runner.
Its becoming quite stiff, so much so that it takes quite a bit of pressure on the camera to turn the camera into portrait mode when using a monopod, ive also recently noticed a little bit of slackness creeping into the mount (not obvious using any other lens) im worried i may cause some damage.
Do you guys know if there is anyway to remove the collar without doing any damage or if i can just try squirting a lube fluid into the gap between body and collar.
bildeb0rg
Gallery: 795 photos
Jan 15, 2009 11:43 |  #2
Depends on what's causing the stiffnes, could foreign body or misalignment. Has it had a knock?.
You could try a shot of WD40, but that might make it worse in the long run by creating an abrasive slurry that grinds away at the bearings/runner.
I would give Fixation a call and see what they suggest.
cpo13
Jan 16, 2009 12:28 |  #3
Gaz,
Have you seen these threads at sportshooter?
http://www.sportsshoot​er.com …ge_display.html​?tid=26905 (external link)
http://www.sportsshoot​er.com …ge_display.html​?tid=26999 (external link)
Seems to be quite a common problem. At the bottom of the second thread are a set of pictures that show how to inspect the bearings
http://www.sportsshoot​er.com …pe/400bearings/​index.html (external link)
Chris
gasrocks
Jan 16, 2009 12:31 |  #4
Not WD40, that is an oil. Will spread. Look inside the collar at the nylon guides. Damage, scratches? A very small amount of silicon spray maybe.
rdompor
Jan 16, 2009 17:12 |  #5
Before you go off using WD-40 I feel that I should mention that motocrossers use it to slide new rubber grips onto the handlebars because it is slick, but then it dries and is almost like an adhesive and causes the grip to stick.
Ramon
ULTRAMONTAGNE (external link)
Website (external link)
bildeb0rg
Gallery: 795 photos
Jan 16, 2009 19:08 |  #6
bildeb0rg wrote in post #7082833 (external link)
You need to read all the words guys...
1,283 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is Nat Zagninski
781 guests, 190 members online
