i know some of the canons can be set to take more than 3 bracketed shots at a time. the question i have is can the 50D do this and if so how ?
Andy
slartibardfast Goldmember 1,000 posts Likes: 10 Joined Jul 2007 Location: Shropshire England More info | Jan 15, 2009 16:12 | #1 i know some of the canons can be set to take more than 3 bracketed shots at a time. the question i have is can the 50D do this and if so how ? www.three6t.co.uk
soren.martensen Member 76 posts Joined Nov 2008 Location: Murwillumbah - Australia More info | Jan 15, 2009 19:05 | #2 Hi Andy, Regards
soren.martensen Member 76 posts Joined Nov 2008 Location: Murwillumbah - Australia More info | Jan 15, 2009 19:25 | #3 sorry forgot to mention - if you use the timer, it will take all three shots without you having to press the shutter button, or this is how it is on my 450D (presume this should be the same on your 50D). This is extremely handy for me as I have a old and shaky tripod and i don't have to touch the camera in between exposures. Regards
canonloader Cream of the Crop More info | Jan 16, 2009 07:22 | #4 Only the 1D MkII and newer bodies can take more than three bracketted shots. So far. The 1D Classic has the option in User Functions, but I have tried it and it didn't work right. Mitch- ____...^.^...____
aymanmb Senior Member 296 posts Joined Jan 2007 More info | have a look at this page and also at the comment at the end of the page Canon 50D | EF-S 17-55 f/2.8 IS | EF-S 55-250 IS | EF 50mm 1.8 | BG-E2N Battery Grip | 580EX II
slartibardfast THREAD STARTER Goldmember 1,000 posts Likes: 10 Joined Jul 2007 Location: Shropshire England More info | Jan 16, 2009 16:59 | #6 thanks all for comments. i take a lot of HDR, but the possability of shake when adjusting the camera to take more than 3 is annoying. i was after any settings to have 9 at a time, but that hope of mine is not going to come true. i will have to use my new sturdy tripod to reduce any camera shake / movement whilst changing the menu setting between bursts will have to surfice www.three6t.co.uk
Jan 16, 2009 17:51 | #7 That's a great link aymanmb, thanks - i just have to figure how to do that with my 40D Sony A7r, Sony 16-35 f4, Canon 1d3, Canon 70-200 f4L, Sigma 150-600 contemporary, G1X, Lee filter holder and gnd's, Singh-Ray reverse gnd
Jan 16, 2009 18:28 | #8 http://www.hdrlabs.com/tools/autobracketing.html FujiFilm GFX 100 | FujiFilm GFX 100s | Fuji X-T4 | Sony Alpha 1 | Sony a7Rv | Sony a7Riva x2 | Sony a7Siii | Sony a7c | No Wife
Serrator Senior Member 291 posts Joined Jan 2007 Location: Missouri More info | Jan 16, 2009 21:23 | #9 Andy, 7d/40d/350d/580EFII...assorted lenses and Photoshop.
slartibardfast THREAD STARTER Goldmember 1,000 posts Likes: 10 Joined Jul 2007 Location: Shropshire England More info | Jan 18, 2009 03:48 | #10 Thanks for all the links, had a busy evening reading them all. i will have to try the +4 to -4 with the exposure adjustment method. www.three6t.co.uk
canonloader Cream of the Crop More info | Jan 18, 2009 05:38 | #11 Overall, the only time you really need to use AEB is when you have a scene with movement in it, such as a landscape with slowly moving clouds. And then, even if you could get more than three frames in high speed burst, it would still cause the alignment problem. You might get away with it for three shots, and they do shoot at 6+ frames a second, but if you could shoot 9 frames, then the movement of the clouds would certainly be noticable. Mitch- ____...^.^...____
Serrator Senior Member 291 posts Joined Jan 2007 Location: Missouri More info | Jan 18, 2009 18:08 | #12 I would add a bit from canonloader's thoughts in that the "only time" when AEB is needed. if you want to view this much larger go here:http://www.flickr.com …in/set-72157601660525826/ Lastly here is a recent image I took using two back to back AEB shots using my 40D (6 exposures). I normally only go with 3 for the most part but since this scene had the sun directly in the view I wanted to go with more range. I do not find any issues with the cloud movements...see for yourself: 7d/40d/350d/580EFII...assorted lenses and Photoshop.
r.morales Goldmember 2,296 posts Joined Apr 2007 Location: Bay Area Calif More info | Jan 20, 2009 01:08 | #13 Today I was reading the book "A short course --XTI" and it said something about the auto flash could go 4 stop in burst mode .
| Latest registered member is semonsters 903 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
