Thread started 16 Jan 2009 (Friday) 14:13
580EXII settings for Indoor B-Day Party
AzzKicker
Joined Jul 2003
Jan 16, 2009 14:13 |  #1
A very good friend of the family asked if I could take pictures at his Mothers B-Day. I told him yes. The only problem is I'm new to shooting a 1D and I just got my 580EX Flash today. Now I know how to set everything Manually and use the flash more or less. I'm not that N00b. But since this is a party he wants me to just shoot candid moments here and there so my DISTANCE between subjects will be changing. I'm used to posed shots where I can set everything manually. Since this will be indoors should I just set my Camera to M and a high ISO for ambient lighting. Should I set the camerea to something like F2.8 and 1/60 and ISO 800? and let the flash do the rest? Or should I just Set cam to P and bounce off ceilings since it will be indoors in a house with a ceiling around 10-12 ft.
Ruben D. Zamora
Canon 6D Mark II, Canon 20-35L,Genesis 200 Strobe
bohdank
Jan 16, 2009 14:22 |  #2
Set the camera to 1/250... pick an aperture and set the flash to ETTL. Bounce it, you'll be impressed with the output. You might have to do some +- FEC compensating but once dialed in, usually doesn't have to be changed.
EDIT: I forgot ISO 200, higher if you really need it.
Lotto
Jan 16, 2009 14:28 |  #3
My favorite setting for indoor bounce shot is f4-5.6, 1/30 to 1/125 depends on how much ambient is needed, iso 400. Camera always in M, flash in ETTL with +2/3 FEC and bounce.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
bobbyz
Jan 16, 2009 14:44 |  #4
I am going to be doing same tomorrow and also for the very first time. I agree with Lotto about the ss.
Lotto - What gel you suggest if any?
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
sdipirro
Jan 16, 2009 15:04 |  #5
I don't think 1/250 would be necessary unless you're really expecting his mother to be running around! I also wouldn't use f2.8 - just too shallow a DOF and risk too many OOF shots. I'd shoot in M mode at 1/125 and f5.6 -f6.3 and ISO 400 (as a nice compromise), bounce the flash and let it do the rest.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
Lotto
Jan 16, 2009 15:04 |  #6
I have some warming gels but hardly use them. I like the flashed subject against warmer background, kind of preserve the natural mood. If the ceiling is low enough, I can always turn up the shutter speed and blast the BG too.
sdipirro
Jan 16, 2009 15:05 |  #7
Oh, and make sure the flash is set to ETTL mode...
dan ­ j
Jan 16, 2009 15:27 |  #8
sdipirro wrote in post #7091216 (external link)
I think the reason he suggested 1/250 is so the flash doesn't work as hard/quicker recharge not to stop motion ;)
dan
5D Mark 2/24-70L/100-400L
dan ­ j
Jan 16, 2009 15:34 |  #9
Oh, and 250th knocks out the ambient light - from the strobist.
dan
bobbyz
Jan 16, 2009 15:42 |  #10
dan j wrote in post #7091339 (external link)
dan
Why would ss effect flash power?
EOS_JD
Jan 16, 2009 15:51 |  #11
bohdank wrote in post #7090946 (external link)
Why such a high shutter speed? You will kill all the ambient light. (woops just saw the rest of the replies :) )
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
AzzKicker
Joined Jul 2003
Jan 16, 2009 15:51 |  #12
What is SS?
Ruben D. Zamora
bohdank
Jan 16, 2009 15:54 |  #13
EOS_JD wrote in post #7091497 (external link)
If you're bouncing, that will effectively wipe out most of the ambient light, anyway. I hate blurry pictures, hence the higher ss/lower ambient light. Also makes WB easier.
dan ­ j
Jan 16, 2009 16:00 |  #14
bobbyz wrote in post #7091444 (external link)
I'll guess that it's because the ETTL flash duration somewhat matches the SS.
Here's a link to the strobists blog. http://strobist.blogsp​ot.com …-balancing-flash-and.html (external link)
The 13th paragraph talks about how 250th is good for recharge and batteries. I've read it other places too, but I don't have time to look it up.
dan <---- not a flash expert - obviously ;)
EOS_JD
Jan 16, 2009 16:06 |  #15
As far as I was aware only the aperture affects flash power. SS Only affects the ambient light which is what the above example provides - a drop of 2 stops of ambient light. Not sure though why this would mean faster recycling though? Maybe someone who knows more can answer that one :)
All My Gear
4,658 views & 0 likes for this thread
Latest registered member is ejkimaging
1752 guests, 207 members online
