On my 20D, when I would focus using autofocus, the focus point would light in the viewfinder. On my 5D MK2, this is not the case. It seems to focus fine, but I really like having the focus point(s) light up. Is this normal?
rfreschner ishka bibble 2,576 posts Joined Jan 2005 Location: Andover, CT...................... Go Red Sox! More info | Jan 18, 2009 08:50 | #1 On my 20D, when I would focus using autofocus, the focus point would light in the viewfinder. On my 5D MK2, this is not the case. It seems to focus fine, but I really like having the focus point(s) light up. Is this normal? Rick
rfreschner THREAD STARTER ishka bibble 2,576 posts Joined Jan 2005 Location: Andover, CT...................... Go Red Sox! More info | Jan 18, 2009 09:13 | #2 I thought about it some more and realized that I had all focus points selected whereas, on my 20D, I generally used only the center focus point. Rick
DarthMTS47 Senior Member 547 posts Joined Oct 2007 Location: Cleveland, Ohio More info | Do you have your 5D set in AI Servo instead of One Shot mode? I don't think that the AF indicators light up when shooting in AI Servo mode.
rfreschner THREAD STARTER ishka bibble 2,576 posts Joined Jan 2005 Location: Andover, CT...................... Go Red Sox! More info | Jan 18, 2009 18:14 | #4 DarthMTS47 wrote in post #7102715 Do you have your 5D set in AI Servo instead of One Shot mode? I don't think that the AF indicators light up when shooting in AI Servo mode. -Mike Thanks Mike. I did and changed it and it made no difference. I also checked my 20D and it worked in AI Servo mode. Rick
yokotas13 Senior Member 558 posts Joined Oct 2006 Location: myrtle beach, south carolina More info | Jan 18, 2009 19:17 | #5 i thought i saw a menu option to turn it off -Grant
rfreschner THREAD STARTER ishka bibble 2,576 posts Joined Jan 2005 Location: Andover, CT...................... Go Red Sox! More info | Jan 18, 2009 19:27 | #6 yokotas13 wrote in post #7105835 i thought i saw a menu option to turn it off i could be wrong, but if it is the case, maybe you turned that indication off. I'll check. Do the focus points light up on yours when you have all of them selected? Rick
BlueS2 Goldmember 1,352 posts Likes: 1 Joined Aug 2004 Location: US More info | Jan 18, 2009 19:35 | #7 Focus points light up just fine on my 5DmkII. You must have some setting turned off. Search for the "superimposed" option. That turns the light off or back on. You want the superimposed image. That will make the squares blink red on autofocus and on selection. Canon 5DmkII / Canon 5D / LifePixel IR 350D / L-glass
rfreschner THREAD STARTER ishka bibble 2,576 posts Joined Jan 2005 Location: Andover, CT...................... Go Red Sox! More info | Jan 18, 2009 19:47 | #8 Blue S2 wrote in post #7105945 Focus points light up just fine on my 5DmkII. You must have some setting turned off. Search for the "superimposed" option. That turns the light off or back on. You want the superimposed image. That will make the squares blink red on autofocus and on selection. My superimposed image function is on. The focus points light up just fine when I select a specific point, but when I have all of them selected, none of them light up when focus is achieved. Thanks for the tip though. Rick
beepclick Goldmember 1,850 posts Joined Mar 2008 More info | Jan 18, 2009 19:59 | #9 The default behavior is when all focus points are active, when you half press the shutter, the points that achieve focus will light up red. This can be turned off, I forget exactly where. The answer is in your manual. I have found it useful to download the PDF version of the manual, which gives you the Search function, so you can view all the pages that have the phrase "active focus points" or "focus confirm light" or something like that. Gear https://photography-on-the.net/forum/showthread.php?t=635450
rfreschner THREAD STARTER ishka bibble 2,576 posts Joined Jan 2005 Location: Andover, CT...................... Go Red Sox! More info | Thanks beepclick, I believe that's the same setting that Blue S2 pointed out - the "superimposed" option. It seemed strange to me that the focus points would light up when I selected an individual one, but not when I selected all of them so I started playing around with different things. I may be on to something, but I've got to finish watching the Steelers game before I pursue it further. Thanks for your help! Rick
| Latest registered member is zachary24 1429 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
