I'm having trouble understanding how my Sekonic L-558R works in cordless flash mode (not using PW's).
I have a two flash setup, camera set at 1/125s and f/7.1 and with the power dialed down on both flashes such that the exposure is correct (no clipping in the histogram and image looks correct in CS3).
I then:
1. Set my Sekonic light meter to incindent reading (dome up), cordless flash mode (lightning bolt) and 1/125s to match the camera shutterspeed.
2. I push the measuring button, position the meter to read incident light falling on the subject then fire away.
The meter then gives a reading of f/2.8 ... not 7.1, which is what is confusing me. I've also tried cumulative mode and manually tripping the flashes in case the pre-flash is messing up the reading but get the same result.
If the image is properly exposed shouldn't the result be f/7.1, or am I reading it wrong? If I set the camera to f/2.8 the image is totally blown out.
When I set the meter for reading ambient it gives a reading that matches my cameras light meter.
