Thread started 20 Mar 2005 (Sunday) 19:32
flash on 20D
ElleG83
Mar 20, 2005 19:32 |  #1
anybody know if there is a way to decrease the intensity of the flash on the 20D? i seem to have misplaced my owners manual...
Canon EOS 20D :-D
75-300mm
35-80mm
17-40L
50mm 1.4
tim
Light Bringer
Mar 20, 2005 19:36 |  #2
Flash Exposure Compensation. Hit the button with a little lightening bolt on it, then dial it down.
robertwgross
Joined Nov 2002
Mar 20, 2005 20:00 as a reply to  @ tim's post |  #3
If your internal flash is already at its maximum, then your best bet is to crank up the ISO of the camera. That effectively gets you more flash range, even though you really are not changing the flash.
---Bob Gross---
tim
Light Bringer
Mar 20, 2005 20:15 |  #4
Bob, he said decrease the intensity. Raising the ISO will have the same effect as increasing the intensity/brightness of the flash.
Another way to get less light in is to use a narrower aperture.
ElleG83
Mar 20, 2005 21:01 as a reply to  @ tim's post |  #5
actually, i'm a she, but that's ok. i understand light just fine. i have a photography assignment where i have to take 3 pictures- one with no flash, one with 1/2 stop flash fill, and one with one stop flash fill. thanks for the help though! :D
Canon EOS 20D :-D
75-300mm
35-80mm
17-40L
50mm 1.4
tim
Light Bringer
Mar 20, 2005 21:05 |  #6
He, she, doesn't matter ;) My first post explains how to do it, good luck with the assignment :)
drisley
"What a Tool I am"
Joined Nov 2002
Mar 20, 2005 21:30 |  #7
Check out Canon. You can download the 20D owner's manual in PDF format.
EOS R6 Mark II - Sigma 50/1.4 Art - Sigma 14-24/2.8 Art - Canon EF 70-200/2.8L Mark III - Godox Xpro-C - Godox TT685C x2
ElleG83
Mar 20, 2005 21:33 as a reply to  @ drisley's post |  #8
lol. yeah. i thought of that right after i posted.
Canon EOS 20D :-D
75-300mm
35-80mm
17-40L
50mm 1.4
drisley
"What a Tool I am"
Joined Nov 2002
Mar 20, 2005 21:54 |  #9
The great thing about PDF is that you can do a search for the topic you want.
It's so much faster than flipping thru pages. :)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 20, 2005 22:00 |  #10
Elle,
As you increase/decrease the Flash Exposure Compensation as described bu Tim above,.. there is an exposure meter very much like the one in your viewfinder on the 20D's top LCD.. But this one shows your Flash metering.. there you will allways see if you have FEC set, and where it's set to.
CDS' HOT LINKS
robertwgross
Joined Nov 2002
Mar 20, 2005 23:55 as a reply to  @ tim's post |  #11
You're right. I've never heard of anybody trying to decrease the intensity, only increase it.
The light will decrease automatically, down to one meter. Beyond that, you're on your own. You could simply put a heavy diffuser over the flash tube. The metering will see that effect from the pre-flash and try to goose it up some, but it can only go so far.
---Bob Gross---
drisley
"What a Tool I am"
Joined Nov 2002
Mar 21, 2005 00:56 |  #12
I always decrease the intensity of the flash because I almost always use it as a fill.
pierrot
Joined Jan 2005
Mar 21, 2005 04:39 as a reply to  @ drisley's post |  #13
So do I very often (more than increasing, which I do with a 550ex ;) )
Eos 5D + Eos 7D + Eos 20D + f/1:1 L eye-glasses
5,003 views & 0 likes for this thread, 6 members have posted to it.
flash on 20D
1210 guests, 129 members online
