Thread started 09 Dec 2002 (Monday) 14:54
G3 RAW conversion
Cray
Joined Dec 2002
Dec 09, 2002 14:54 |  #1
Does anyone know any raw-convcerter for Canon G3 ? which can handle raw to 48bit tiff conversion?
recommendations, please.
Roger_Cavanagh
Joined Sep 2001
Dec 10, 2002 05:20 |  #2
Cray,
Other than Canon's own, I don't think you'll get one yet. Third-party developers are apparently still waiting for the updated Canon SDK, but I don't think it will be too long.
Regards,
Roger Cavanagh
www.rogercavanagh.com (external link)
tsoutherwood
Joined Jan 2003
Jan 27, 2003 08:26 |  #3
Hi Cray
Try:
http://www2.primushost​.com/~dcoffin/powersho​t/ (external link)
Dave Coffin wrote a basic decoder that is one C file.
Beware the caveats on the page Re: 48 bit TIFF. But it does work.
It is also only a simple converter - when shooting in RAW mode (at least on a G3) the pure sensor RGB data is dumped into the RAW file. The accompanying THM thumnail is a JPG with EXIF data on the whitebalance, ISO and all other settings chosen at the time of the shot.
Canon's own software uses this to apply whitebalance and sharpening (or special effects like sepia, B&W etc) after the event.
So for example, if you dump a RAW shot under tungsten, even if you set AWB or Tugsten whitebalance on the camera, the RAW will decode to be very colour cast with yellow.
This isn't a fault - it's just a lack of implementation.
Assuming you want to fixup any pictures in Gimp or Photoshop
then it should work for you.
Cheers
Tim
gandini
POTN's April Fool!
Joined Apr 2001
Jan 27, 2003 11:31 |  #4
Actually, BreezeBrowser converts G3 RAW, as does Canon's FVU, but neither is able to convert in linear mode yet, since there is a problem with Canon's SDK code. Chris Breeze is waiting on an update, as are other developers I presume.
Till then, you can convert to 8 or 16 bit TIFF, or JPEG of course, with all the parameter selections (WB, contrast, sharpness, etc.) intact.
cheers,
2,032 views & 0 likes for this thread, 4 members have posted to it.
G3 RAW conversion
1597 guests, 129 members online
