John E wrote in post #7116201
Thanks, Mike. I always thought that the 580 ex II (and other flashes) emitted only one color temperature, but apparently it varies. So now I'm thoroughly confused. How do you get consistent flash color (i.e. with gels)?
Color temp shouldn't vary that much unless you shoot when it's not charged, it'll change by a few hundred K at most IMHO.
eduardofrances wrote in post #7117623
The best way would be the use of a gray card (like Whibal
), you take a shot at beginning of the photoshoot and you correct color discrepancies in post processing with the shots of the gray card for each scenario you were doing.
Those of you following along at home will see the flaws in this plan... ie that the color temp changes with each shot, not per situation.
I suggest people stop worrying about tiny things, shoot studio work on RAW + JPEG and use the JPEG if it's ok or switch to RAW if you need changes.
