A couple jets flying around Davis Monthan AFB in Tucson, Az. First week with the camera, and def first time trying to photograph something moving this fast..
Pictures cropped but otherwise untouched...
Karpov Hatchling 2 posts Joined Jan 2009 More info | Jan 19, 2009 17:18 | #1 A couple jets flying around Davis Monthan AFB in Tucson, Az. First week with the camera, and def first time trying to photograph something moving this fast..
ogre1231 Goldmember 1,137 posts Joined Mar 2008 More info | Jan 19, 2009 17:34 | #2 it's definitely not easy. I've tried my hand at it a few times, but work usually gets in the way. first one's pretty fuzzy, but second one doesn't look too bad. did you try panning your movements with the plane? keep practicing. thanks for sharing and welcome
duntov Senior Member 463 posts Joined Mar 2006 Location: Fussa, Japan More info | Jan 19, 2009 18:10 | #3 What kind of shutter speed did you use? Canon 7D,Canon 5D, Canon 40D, Canon Rebel XT, Canon 85 1.8, Canon 50 1.4 Canon 100-400 mm L, Canon 70-200 F4 L, Canon 17-40 F4 L, Canon 24-70 F2.8, Canon 100 Macro 2.8, Speedlite 430EX (X 2), Elinchrom D-Lite 4 set to go
sixsixfour Goldmember 1,781 posts Likes: 26 Joined May 2007 Location: Orange County, CA More info | Jan 19, 2009 19:17 | #4 first one looks like it was taken in the digital zoom range of a P/S. Canon 7D / 50D / 30D / SL1 / XT
PhotosGuy Cream of the Crop, R.I.P. More info | Jan 19, 2009 19:25 | #5 Keep at it. It does get easier. Check the links in here: FrankC - 20D, RAW, Manual everything...
nedwards Member 77 posts Joined Jan 2009 More info | Jan 20, 2009 06:07 | #6 Good start mate...i made my first tender steps into aviation photography almost exactly a year ago! Things to remember...if you're shooting pointy fast things...use a fast shutter rate...for slow lumbering things with props...shoot as slow as you can go (generally between 1/60 - 1/250)...i found panning hard but, as opposed to panning and just scatter gunning, i use single shot and try to keep a ryhtm hitting the shutter, it kind of keeps me steady...lastly, try and get as close to the flight line as you can..or! find out where the dog leg turn into approach is so you can catch a good topside (like the '16) when they bank..often if they see you there they get a bit showboaty and play for the camera a little...well, your boys in the '15's do at Lakenheath! Neil Edwards
| Latest registered member is IoDaLi Photography 1631 guests, 141 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
