Thread started 19 Jan 2009 (Monday) 19:00
Indoor sports - 4 lights?
jharms1
Jan 19, 2009 19:00 |  #1
I've been shooting indoor sports (volleyball, basketball) with two speedlights (580 EX & 580 EXII) triggered remotely using pocketwizards. I've been getting pretty good results but I want to do better. I just purchased a couple of Vivitar flashes, pocketwizard, and supporting cables and mounting hardware. I haven't shot a game with 4 lights yet and am not real sure the best way to position the lights.
Has anyone shot indoor sports with 4 lights? If so, can you give me some advice on placement?
:D Canon EOS 1D X & 1D Mark IV
- Canon EF 400mm f/2.8L IS USM
- Canon EF 70-200mm f/2.8L IS II USM
- Canon EF 24-70mm f/2.8L USM
http://roundrocksportp​hotos.com (external link)
40Dude6aedyk
Jan 19, 2009 19:06 |  #2
Maybe post your question on that SportsTalk thread?
I have found that putting the lights behind me and bouncing off the ceiling is better than spreading them out. This is different from what others have done. You have to decide what your style is. Do you like direct light? Bounced light? I find that direct light and light not behind me gives unnatural shadows that I don't like. I also do not like the background to be darker than the background, but some folks like the separation they get when they do this.
Anyways, this kind of stuff is discussed ad nauseum in the SportsTalk thread. See e.g. https://photography-on-the.net/forum/showthre​ad.php?t=629606
I see you have already posted over there. See you there again soon.
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs
jeromego
Jan 19, 2009 19:45 as a reply to  @ 40Dude6aedyk's post |  #3
im just wondering, do they allow you to set up lights in the gym? i.e. high school basketball?
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
scot079
Jan 19, 2009 19:53 |  #4
jharms1 wrote in post #7113036 (external link)
It might be overkill unless you want both ends of the court covered or are bouncing off the ceiling (not getting enough light).
I set my lights at the top of the bleachers, facing each other. Pretty much just like "the strobist" suggests. If you were able to have a setup like that at each end of the court, it might be nice.
Question: Do you have battery packs for your flashes? If not, I would get that before adding more lights. Just so you don't run out of power.
jeromego wrote in post #7113344 (external link)
Yes, I do not shoot during free throws though, that might be a little distracting.
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
jharms1
Jan 21, 2009 07:30 |  #5
Thanks, all. I'll pose this question in the sports talk forum too.
Yes, they allow strobs in most high school indoor sports. I find that it works best to ask both coaches first then confirm with the refs. That way no one is surprised.
I shot basketball yesterday with 4 lights. I set two facing each other (like on the strobist suggests) and then the other two in the same location but pointed down court. I had all flashes at 1/2 power. I didn't get great results. The wall at the far end of the court was blown out. It certainly helped to light the back court. I just need to play around with placement and power. I may try bouncing a couple off of the ceiling and a couple direct. Maybe that would help on the shadows that sometimes occur with direct flash.
I do have a battery pack (Quantum Turbo 2x2) but I rarely use it. The rechargable batteries seem to work fine. I shot nine volleyball games last weekend on the same charge and never had a flash failure. I bought the Turbo 2x2 to try and shoot 3 frames per secound at football games but the 580 EXII won't keep up even with the battery pack (unless I'm doing something wrong). Anyone have any success shooting in continuous mode with a flash?
fitzhughsmith
Jan 21, 2009 07:58 |  #6
I'm shooting a 580EX in ETTL mode using a Quantum Turbo batterry at motorsports events. I'm also using a Mark III at 3200 ISO and usually a 70-200 F2.8. If I'm in low speed mode, about 3 frames/sec, I'll get 1-2 flashes a sec so quite a few frames are underexposed. So what you are seeing is about right.
Mark III, 5D, 70-200 f2.8 IS
1,251 views & 0 likes for this thread, 5 members have posted to it.
1017 guests, 122 members online
