Thread started 22 Jan 2009 (Thursday) 10:47
Canon 1D mkII registered AF point
DisrupTer911
Jan 22, 2009 10:47 |  #1
Is it possible to register multiple single AF points so that you can tab/scroll through them using the "assist/white balance correction" button found above the quick control dial?
Or can only 1 AF point be registered at a time?
www.vividemotionphotograph​y.comexternal link
HighPixel
Jan 22, 2009 20:46 |  #2
If I remember right, one is registered, but can have an expanded function...
HP
No longer actively shooting...
Canon EOS-1DMk.III
| Canon EOS-5DMk.II / BG-E6 | Canon 70-200 2.8LIS Mk.II | 24-70 2.8L | 16-35 2.8LII | Just all kinds of crap...|RonBaltazar.com (external link)
equetefue
Gallery: 230 photos
Jan 22, 2009 21:12 |  #3
correct
http://www.Photo-Galleria.com (external link)
Powered By Canon
EOS R l 5D MkIV l 7D MkII l 5D l 30D IR l 500mm f4 L IS l RF 24-105mm f4 L l 50mm f1.8 l 17-40mm f4 L l 135mm f2 L l 100-400mm f5.6 L L IS II l 100mm f2.8 USM Macro l EF 1.4x III l EF 2.0x III l 580EX II
René ­ Damkot
Jan 23, 2009 06:40 |  #4
You can register one AF point.
If you use CFn4 (* to focus), you can set up CFn 11 (IIRC, not near the camera ATM) to switch to the registered AF point "only while pressing X" (the button left next to the * button).
I have it set up like that, and * gives me AF at whatever AF point I have selected at the time, X gives me ROF AF.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
DisrupTer911
Jan 23, 2009 07:35 |  #5
yeah that's how I have it set now.
On the bodies with the multi-direction control stick, when you press it in, it goes to CF AF point automatically. and pressing the AF selection button enables all teh points.
Is there a way to set the body to have 1 registered point, then use the AF point select button to use the dials to scroll to a new spot but then another button or button combo to go back to center?
René ­ Damkot
Jan 23, 2009 08:34 |  #6
Not sure what you're asking exactly, and I only know how a 1D(s)(Mk2) works, but you can select a different AF point for the * and X button. So you have two to choose from.
HighPixel
Jan 23, 2009 09:40 |  #7
René Damkot wrote in post #7169680 (external link)
I think you may have to register the point each time...I could be wrong.
HP
Canon EOS-1DMk.III
René ­ Damkot
Jan 23, 2009 11:14 |  #8
HighPixel wrote in post #7170064 (external link)
HP
Once registered, it stays registered...
DisrupTer911
Jan 23, 2009 13:02 |  #9
oh well lol guess i'm used to my 20D and 30D having the multi-direction controller that you can press in to get back to center only.
1,466 views & 0 likes for this thread, 4 members have posted to it.
1084 guests, 115 members online
