I own the original EF 75-300 f/4-5.6 IS USM lens (the first ever Canon IS lens) and have been considering replacing it with something better (sharper and better IS).
I don't use my telephoto lens that much, but it does see occasional use for wildlife and travel photography. Lack of use is the main reason I don't want to spend alot on a tele-lens upgrade, but if I had a better one then maybe I'd use it more. I'd be comfortable spending $400-500 plus whatever I get for my old lens (maybe $300 max).
My understanding is that the EF 70-300 IS USM that replaced my 75-300 is sharper at 300mm and has better IS. Is it worth switching to the 70-300 IS or is my money better spent elsewhere?
Should I consider the EF-S 55-250 IS at all? I assume the IS is better than mine, but I'd lose 50mm at the long end and doubt the 55-250 is any sharper at 250mm than my 75-300.
Another ption is to go the L route (70-200 f/4L IS + TC or 100-400L IS) but that is probably more than I want to spend right now.
I'm open to non-Canon suggestions as well. I haven't researched those yet, but I'll bet there are some good ones.
I own a Rebel XT, and don't plan to buy a FF body so I'm open to lenses that don't work on a FF body. I also have a Promaster 1.7x teleconverter, but I don't know if it's worth using.
