of getting rid of those floating platforms in the upper middle of the pic? I'm using CS3, and I'm a complete newb to advanced post, so please be gentle
TaDa ...as cool as Perry 6,742 posts Likes: 3 Joined Feb 2008 Location: New York More info | Jan 22, 2009 19:28 | #1 of getting rid of those floating platforms in the upper middle of the pic? I'm using CS3, and I'm a complete newb to advanced post, so please be gentle Name is Peter and here is my gear:
tango Member 79 posts Joined Jan 2008 Location: Edmonton, Alberta, Canada More info | Jan 22, 2009 19:57 | #2 The first tools that come to mind are the clone stamp tool or the patch tool. Tango
TekHouse Goldmember 1,289 posts Likes: 1 Joined Nov 2007 Location: Earth More info | Jan 23, 2009 03:05 | #3 The patch tool works..I just edited it and it looked fine. But anyway, I used the patch tool to draw around the floats and then dragged to the snow and ice on the side. Photoshop then blends the area you dragged to with the area you drew the patch onto. If you do this a few times you will have the basic effect. After that you need to do some minor touch up with the paint brush to make the edges match. The biggest task, and its not so big if you know photoshop, is the sun reflection. I used the eye dropper and selected the brightest color in the fore ground reflection, chose a large sized airbrush and took flow to 35% and opacity to about 50%, then painted over the patched areas recreating the suns reflection. Now I use a WACOM so this is easy, I would say you could do it with the mouse but you would need to take more care. After the sun reflection was in place I eye droppered (is that a word?) the ice lying next to it, its a bluish grey, and again used the same brush settings to kind of fog in the edges. Zoomed back out to 100% using the photo up there, it looked spot on. If you want you can send me the raw and I will do it for you and then upload the PSD so you can see my work. PM me if you want.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jan 23, 2009 03:32 | #4 A rope and four strong men Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
TekHouse Goldmember 1,289 posts Likes: 1 Joined Nov 2007 Location: Earth More info | Jan 24, 2009 05:46 | #5 OK TaDa sent me the original RAW file..This is the result..I was amazed to see the detail come out at the bottom of the pic..You can now see tracks clearly in the snow where some animal has walked on it!
| Latest registered member is semonsters 1024 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
