Thread started 23 Jan 2009 (Friday) 23:29
Wide Angle. Canon, Sigma
Nick5
Jan 23, 2009 23:29 |  #1
I do not have a wide angle lens for my 40D as of yet. I keep pushing back the wide angle for other equipment.
I do not have any non Canon lenses in my arsenal. I have heard good things about the Sigma 10-20. How does this compare to the Canon 10-22 and which would you recommend?
Thanks.
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jan 24, 2009 00:07 |  #2
Here is my direct comparison of the two. In all honesty, both are good lenses with it's pro/con's. If the cost difference is not a factor, I'd go for Canon, if it is, I'd go for Sigma. Having said that, I'd go for a Tokina 11-16 which I had as well.
Gallery: http://tomyi.smugmug.c​om/ (external link)
agunther
Jan 24, 2009 00:12 as a reply to  @ Tee Why's post |  #3
I have had a Tokina 12-24 which nicely extends my Canon 24-85 towards the wide end. I just love this lens, even though it requires a bit of tweaking during RAW conversion to keep the chromatic aberrations in check.
You should check it out as well.
My Travel Photos (external link)
California Photo Scout (external link)
yokotas13
Jan 24, 2009 01:33 |  #4
canon all the way
I love my 10-22, too bad i have to sell it now since i went 5d
-Grant
[URL=http://photograph​y-on-the.net/forum/showpost​.php?p=7493258&postcou​nt=1706]Gear List
check the blog- www.wagonofdoom.wordpr​ess.com (external link)
Jeff81
Jan 24, 2009 02:58 |  #5
agunther wrote in post #7175104 (external link)
Definitely check out the tokina 12-24. Solid build and great image quality. I rarely have any problems with CA, but if I do, its easy to fix as previously mentioned. This lens is a steal.
R6/6D | Canon 24-105L f/4 IS, Samyang 24 f/1.4, Sigma 50 f/1.4 Art, Canon 85 f/1.8, Canon RF 70-200 L f/2.8 IS
Feedback
Roy ­ Webber
Location: Corralejo, Fuerteventura....Canary Islands Spain
Jan 24, 2009 05:53 |  #6
The 10-22 is an excellent choice, and probably has better QC than the sigma.
Canon 7D, 40D,100-400 IS L, EFS 15-85 IS, EFS 10-22-With Faulty USM, 055XPROB+488RC2, 430 & 580 II Flash, Tokina 11-16mm f/2.8-:cool:
noodle_snacks
Jan 24, 2009 06:40 |  #7
But the sigma has a superior build, and is better value in my view.
troutfisher
Gallery: 23 photos
Jan 24, 2009 06:50 |  #8
Depends how much you want to spend. I have the sigma and as far as I am concerned it is fine. I have not used the Canon so I can't comment on it but from general comments the sigma seems OK and better value.
Chris
" Age and treachery will always defeat youth and enthusiasm"
Dave ­ R.
Jan 24, 2009 06:54 as a reply to  @ troutfisher's post |  #9
You can read reviews here. http://www.photozone.d​e/canon-eos (external link)
John_B
Gallery: 178 photos
Jan 24, 2009 06:55 |  #10
Nick5,
I have been very happy with my Canon 10-22 f/3.5-4.5 lens.
click to see (external link)
cctsm
Jan 24, 2009 06:57 |  #11
I have the Sigma, and it's really pretty decent. Fast and silent AF, good build quality. It does flare a bit easily, but then all UWAs do.
Since the Canon supposedly performs better flare-wise, I do somewhat regret my choice; assuming you don't plan to have the sun in the frame you shouldn't really worry, though. It's one of my most-used lenses as it is.
Canon: EOS 50D, EOS 400D, EF 300mm f/4L IS USM, EF 50mm f/1.8 II, EF-S 18-55mm f/3.5-5.6 II, EF 1.4X Extender, Speedlite 430EX
Sigma: 10-20mm f/4-5.6, 55-200mm f/4-5.6 | Tamron: 17-50mm f/2.8 | Manfrotto: 055 XPROB tripod, 680B monopod, 804RC2 and 486RC2 heads
Kenko extension tubes, Sandisk Extreme III 2GB + 8 GB & Ultra II 4GB
TATER64
Jan 24, 2009 07:03 |  #12
I have not used the Canon so cannot comment on it ,Alas i,m very happy with the Wigma and it is very good value,i saved roughly $300 over the Canon
The lens sample archive has some very impresive images taken with the Wigma which persuaded me into the purchase of the Sigma over the Canon.
Canon 40D,Wigma 10-20mm,Canon 50mm F1.8 MkII, Canon EF-S 18-55MM IS,Canon 24-105mmL IS USM,Canon 70-200mm L IS F/4, Hoya CPL,Lowepro sling shot 200 back pack,Naneu Pro UrbanGear U60 Backpack
Spud
Flickr (external link) Photos
nightcat
Jan 24, 2009 07:37 as a reply to  @ TATER64's post |  #13
If you don't mind a slightly shorter range, you should also consider the Tokina 11-16mm 2.8. The test on Photozone (and other websites) rate this as a slightly better lens as far as image quality over the highly rated Canon. The build of this lens is outstanding as well.
nik.hisham
Jan 24, 2009 08:56 |  #14
Tokina 11-16 2.8 is worth a look. Check out the reviews in photozone. You can compare MTF numbers between the Tokina, Canon and Sigma. Based on Photozone's review, the Tokina comes out on top in all areas except CA.
But as far as UWA goes, I think you won't go wrong with any of the three. I have seen some really really good shots from all three lenses in the samples thread.
Nik.
5D Mark II | 50 F1.8 II | 35L | 17-40L | 38-76 "Macro" | 580EX II | 430EX
bohdank
Jan 24, 2009 10:13 |  #15
When I was looking for a UW I narrowed it down to the Canon and the Sigma. I would have looked at Tokina also but they have very little presence in Canada.
I chose the Canon because I hate second guessing myself. Sigma is known for focusing issues, needing to send it in for calibration and the Canon just seemed to have better reputation.
Although more expensive I bought the Canon and do not regret paying the higher price for it.
2,648 views & 0 likes for this thread, 17 members have posted to it.
1474 guests, 132 members online
