Thread started 24 Jan 2009 (Saturday) 15:02
ETTL along with PC terminal?
dan ­ j
Jan 24, 2009 15:02 |  #1
I do most of my lighting using ETTL. I'd like to add another flash just for background gels. I'd prefer not to spend the money on a Canon flash if I'm just using it for BG lighting. So can I use the ST-E2 (mounted on the hotshoe) and use the PC terminal to trigger the BG flash at the same time (maybe using the cheapo Cactus triggers)?
My other option would be to use an optical trigger, but I'm not sure if there's one that works well with ETTL's test flash.
Thanks,
dan
5D Mark 2/24-70L/100-400L
Lotto
Jan 24, 2009 15:32 |  #2
Yes you can use the Canon master on hotshoe and use the PC port at the same time.
I add a sync port to my ST-E2, sometimes I use it as focus assist for my eBay trigger.
IMAGE: http://farm2.static.flickr.com/1247/3170418320_f36f1da8af.jpg
5D, 24-105L, 70-200L IS, 85mm Art, Godox
dan ­ j
Jan 24, 2009 16:02 |  #3
Great, thank you. You're picture looks really interesting. But, too much work for me ;)
Thanks,
dan
738 views & 0 likes for this thread
Latest registered member is LeonWang
1055 guests, 224 members online
