Thread started 24 Jan 2009 (Saturday) 16:34
Question: Why can't I get my ss higher than 250 when shooting basketball?
nickybegood1998
Jan 24, 2009 16:34 |  #1
Good afternoon,
Let me start by saying that I typically shoot soccer so my boys are new to basketball. I have been reading and practicing and reading some more. I have a question though...
I have a 30D, using 85/1.8 and 430EX flash. The lighting stinks in the gym but I'm wondering why I can't get higher than 250 for my shutter speed?
I'm shooting in manual, ISO 1600, aperture in the 2.0's and I cannot get any higher than 250 for shutter speed. What am I doing wrong? I know I need to keep my ISO high so I haven't been adjusting that so I really only have the aperture to play with. No matter what I do, I can't get it.
Do I have something set incorrectly on the camera that is preventing me for reaching a higher ss?
Thanks for the insight.
Karman
7D Gripped, 30D Gripped, G10 | Tamron 28-75 2.8 | Canon EF 50 1.4 USM, 85 1.8 USM, 28-135 IS |Sigma 70-200 f/2.8 | Canon 430EX | Lowepro 300 AW & Toploader 75 AW | Sigma 1.4 TC
FOX2PRO
Jan 24, 2009 16:38 |  #2
Hmm. That is wierd. I know the built in camera flash can't sync beyond 1/200, but i didnt think that applied to the externals.
Gear: |Rebel XT| 18-55 Kit | 70-200f4 | 50 1.8 |
nickybegood1998
Jan 24, 2009 16:42 |  #3
What is even stranger is that I can set the ss to say 500 or 640 or whatever and then when I go to shoot, it's back to 250. I just don't get it.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jan 24, 2009 16:44 |  #4
FOX2PRO wrote in post #7178878 (external link)
Max x-sync applies to both external and pop-up flash and is typically 1/200s or 1/250s depending on the camera body. However, with a Speedlite you can set it to HSS (high speed sync) and fire away at whatever shutterspeed you want. Flash output is significantly reduced in HSS mode though.
Bob
nickybegood1998
Jan 24, 2009 16:45 |  #5
What is really weird is that I can set the ISO to 500 or 640 but when I get ready to shoot, it's back at 250. I know it has to be me but I don't understand what I'm doing wrong.
EOS_JD
Jan 24, 2009 16:47 |  #6
If you check your CUSTOM OPTOINS in your camera. It must be set to SYNC at a maximum of 1/250th. You should be able to switch auto sync off.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
Bob_A
Gallery: 48 photos
Joined Jan 2005
Jan 24, 2009 16:48 |  #7
nickybegood1998 wrote in post #7178904 (external link)
You have to use HSS :)
Also, remember that if the subject is only being illuminated by flash you could shoot at 1/30s and the image would still be sharp because the flash burst is very fast. To do this though the background exposure (not the subject) would need to be 2-3 stops underexposed :)
Bob
MJPhotos24
Joined Nov 2005
Jan 24, 2009 16:49 |  #8
This should be in the manual (no clue if it is) but you can't get a higher sync than 1/250th using external flash, and that includes strobes. The action is not frozen by the shutter speed it's frozen in the flash duration. If it's a Canon user at the games you see strobes they are all shooting 1/250th at most. Nikon as a few bodies that are 1/500, a friend was just complaining because the new body Nikon came out with was only 1/320 with her strobes.
Freelance Photographer & Co-founder of Four Seam Images
Mike Janes Photography (external link) - Four Seam Images LLC (external link)
FSI is a baseball oriented photo agency and official licensee of MiLB/MLB.
@FourSeamImages (instagram/twitter)
@MikeJanesPhotography (instagram)
@MikeJanesPhotog (twitter)
nickybegood1998
Jan 24, 2009 16:50 |  #9
Let me go and get my camera to check EOS_JD. Please keep the suggestions coming just in case. I'd like to correct this before next Saturday.
Thanks everyone!
EOS_JD
Jan 24, 2009 16:50 |  #10
Look at Custom Function 03. Flash Sync speed in Av Mode 0 is Auto and 1 is fixed 1/250th.
That may be the problem? Set it back to 0
If using higher than 1/250th shutter speed you need to use HSS with the canon Speedlites.
All My Gear
MJPhotos24
Joined Nov 2005
Jan 24, 2009 16:50 |  #11
HSS is NOT intended for sports use, it will NOT help...
http://webs.lanset.com​/rcochran/flash/hss.ht​ml (external link)
nickybegood1998
Jan 24, 2009 16:56 |  #12
EOS_JD, the custom function was set to Auto. I scrolled and saw the fixed 1/250 option but it was set to Auto. Darn it.
nickybegood1998
Jan 24, 2009 17:00 |  #13
Maybe I'm trying to do something that isn't possible but I could swear that I have read tons of basketball threads here that say they have reached higher ss than what I'm getting. If this is the best that I'm going to get minus strobes, I'm ok. I just wanted to make sure.
MJPhotos24
Joined Nov 2005
Jan 24, 2009 17:08 |  #14
They're not using flash and that's how they're getting higher shutter speeds. The sync speed is 1/250 for Canon except the older 1D's had 1/500, you can manually override it but it won't help. If you manually override it so you're getting 1/500 but your flash is still at 1/250 you'll have a nice picture of your shutter in half the frame. HSS is a lot of short bursts while the shutter is open and will show a lot of ghosting. HSS intended purpose is for fill flash in bright outdoor light.
EOS_JD
Jan 24, 2009 17:11 |  #15
Yes that's right. If using strobes you cannot shoot at higher than the sync speed. Some cameras have a sync speed of 1/500th - maybe that's what you need.....
All My Gear
4,508 views & 0 likes for this thread, 15 members have posted to it.
1027 guests, 106 members online
