I'm trying to get by cheap with what I already have after paying for a 100mm macro lens.
Will my 430EX flash mounted to bogen tripod leg be enough for macro photos taken outdoors?
Jan 26, 2009 22:49 | #1 I'm trying to get by cheap with what I already have after paying for a 100mm macro lens.
doidinho Goldmember 3,352 posts Likes: 23 Joined Aug 2007 Location: Kenmore, Washington More info | Jan 26, 2009 22:55 | #2 I'm don't do Macro, but from what I understand you will be very limited using a shoe mount flash due to shadow from you, your camera, and your lens. I believe thats why people who do macro usually end up buying a ring flash. Robert McCadden
c2thew Goldmember 3,929 posts Likes: 4 Joined Aug 2008 Location: Not enough minerals. More info | Jan 26, 2009 23:01 | #3 psssh. people who do macro create their own bowl diffusers. look up DIY diffusers on flickr. a plastic bowl held to your 430ex flash will diffuse the light very nicely for macro. Flickr
doidinho Goldmember 3,352 posts Likes: 23 Joined Aug 2007 Location: Kenmore, Washington More info | Jan 26, 2009 23:25 | #4 c2thew wrote in post #7195381 psssh. people who do macro create their own bowl diffusers. look up DIY diffusers on flickr. a plastic bowl held to your 430ex flash will diffuse the light very nicely for macro. Yeah, but that wont matter much if you and your camera are between your subject and your light. Robert McCadden
Oteck Senior Member 570 posts Joined Aug 2008 Location: Vancouver B.C. More info | Jan 27, 2009 00:44 | #5 I think it's better if you stick the camera on the tripod while hand holding the flash close to the subject. Canon 7D, 50D/BG-E2N, 580EXII
brecklundin Goldmember 2,179 posts Joined Jun 2008 More info | Jan 27, 2009 00:45 | #6 Real men shoot Pentax because we're born with our own Canon's!!
brecklundin Goldmember 2,179 posts Joined Jun 2008 More info | Jan 27, 2009 00:51 | #7 doidinho wrote in post #7195349 I'm don't do Macro, but from what I understand you will be very limited using a shoe mount flash due to shadow from you, your camera, and your lens. I believe thats why people who do macro usually end up buying a ring flash. why would the OP's own shadow come into play?? I mean it's not like the OP's mounting the flash behind his/her head...at least I hope not... Real men shoot Pentax because we're born with our own Canon's!!
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jan 27, 2009 07:26 | #8 doidinho wrote in post #7195532 Yeah, but that wont matter much if you and your camera are between your subject and your light. ![]() Remember this is macro, so you and your camera are going to be blocking the light from up to 180 degrees around your subject. In case you missed it, the OP was talking about using the flash off camera. ...Leo
Jan 27, 2009 07:43 | #9 Off camera chord will work just fine, as long as you have the flash in the right spot. Most people choose to use a bracket to get the light in the right position. Might be worth looking into. As was stated, check out the DIY threads, I've done a fair bit of DIY, and it can certainly get results.
Jan 27, 2009 14:38 | #10 I don't have much macro experience. But I think with a right set of diffusers and reflectors you can pull this out with a single 430 flash. Do you want to go through the trouble of building such a setup? How often are you going to shoot macro? You may end up buying a macro flash PHOTO-TIPS-ONLINE.com – photo tips, photography reviews
| Latest registered member is semonsters 1504 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
