The exif should be there , I'll check after I post . I had a bunch come out with the yellow cast .
Flash was a 580 II on top of shoe , flash bracket to camera broke [I got it out when I home]
I don't know what I had set wrong .
r.morales Goldmember 2,296 posts Joined Apr 2007 Location: Bay Area Calif More info | Jan 27, 2009 19:17 | #1 The exif should be there , I'll check after I post . I had a bunch come out with the yellow cast .
MaxDemian Member 124 posts Joined Jan 2009 Location: Mexico City, MX More info | Jan 27, 2009 19:41 | #2 I'll go out on a limb and say it's the white balance. I can't see your EXIF data but it might be just me. Canon EOS 450D (XSi) | EF-S 18-55 mm f/3.5-5.6 IS | SIGMA 70-300 4-5.6 APO DG MACRO | EF 80-200 mm f/4.5-5.6 II *4 sale*| EF 50 mm f/1.8 II
nuffi Senior Member 926 posts Joined Nov 2008 More info | Jan 27, 2009 19:42 | #3 Also, the shot is underexposed.
PKSmith Member 207 posts Joined Jan 2009 Location: Manhattan, Kansas More info | Jan 27, 2009 20:43 | #4 I don't have much experience with flash, but I'm going to venture a guess and say that it has something to do with the lighting in the room competing with the flash. Since they are different color temps, the areas in the pic that aren't covered by the flash are going to look much different than the areas that are in the flash. However, I could very easily be wrong. | Rebel XSi | EF-s 18-55 f/3.5-5.6 IS | EF 50 f/1.4 | EF 70-200 f/4L | Speedlight 199A |
thebishopp Goldmember 1,903 posts Likes: 1 Joined Jun 2008 Location: Indiana More info | Jan 27, 2009 20:49 | #5 Also you used a slow shutter speed so you will get more ambient light in and as Max said you will need to adjust your wb. If you really want to get rid of that color in that type of lighting you need to boost your shutter speed. "Please use the comments to demonstrate your own ignorance, unfamiliarity with empirical data, ability to repeat discredited memes, and lack of respect for scientific knowledge. Also, be sure to create straw men and argue against things I have neither said nor even implied. Any irrelevancies you can mention will also be appreciated. Lastly, kindly forgo all civility in your discourse . . . you are, after all, anonymous." My Zen
Jan 28, 2009 09:43 | #6 Thanks , this is the exif data , using PS auto color [I think - didn't post the corrected picture] it came out better ,
lonelyjew Goldmember 1,411 posts Likes: 6 Joined Mar 2008 More info | Jan 28, 2009 09:53 | #7 ISO 400, F/3.5, 1/15s is a lot of ambient light coming in. You were using AV so your camera was exposing for the ambient with the flash just acting as fill. Manual and P modes allow you to expose for whichever light source you want or a balance between the two. Also, those walls look yellow, was the ceiling yellow as well? If you bounce off of a yellow surface everything will come out yellow. Canon 40D
Titus213 Cream of the Crop More info | Jan 28, 2009 12:46 | #8 Get your camera into M mode. Av and Tv will attempt to get a proper exposure with the light it has not taking the flash into consideration. Dave
twiggles Senior Member 763 posts Joined Oct 2008 Location: Ohio More info | Jan 28, 2009 12:49 | #9 Titus213 wrote in post #7206121 Get your camera into M mode. Av and Tv will attempt to get a proper exposure with the light it has not taking the flash into consideration. Your shot is probably mostly ambient light and that orange wall isn't helping. Go to M mode on the camera f3.5 is fine, shutter at 1/200. Let the flash earn its keep. Very Good advice...this will help you considerably. T-Wiggles
Jan 28, 2009 12:53 | #10 Thanks , I'll try P next time .
Jan 28, 2009 13:01 | #11 Thanks again , I bookmarked under WB . Sorry last 2 posts came while I was posting .
| Latest registered member is semonsters 1588 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
