Could you imagine what it would be like if they both used the same mount? Imagine a Nikon body with a mix of Nikon and Canon lenses.
Best of both worlds.
Wow!
n1as Goldmember 2,330 posts Likes: 25 Joined Oct 2007 Location: Salem, OR More info | Jan 28, 2009 18:46 | #1 Could you imagine what it would be like if they both used the same mount? Imagine a Nikon body with a mix of Nikon and Canon lenses. - Keith
toxic Goldmember 3,498 posts Likes: 2 Joined Nov 2008 Location: California More info | Jan 28, 2009 18:48 | #2 you can put a Nikkor on a Canon, autofocus and all, if you just buy an adapter...
SoundsGood Goldmember 1,968 posts Joined Nov 2006 More info | Jan 28, 2009 18:56 | #3 toxic wrote in post #7208546 you can put a Nikkor on a Canon, autofocus and all, if you just buy an adapter... What about the other way around?
KenjiS "Holy crap its long!" More info | Jan 28, 2009 18:56 | #4 toxic wrote in post #7208546 you can put a Nikkor on a Canon, autofocus and all, if you just buy an adapter... Er..you lose AF and automatic diaphragm..But you can Gear, New and Old! RAW Club Member
S.Horton worship my useful and insightful comments More info | Jan 28, 2009 19:39 | #5 Canon should just but Nikon. Sam - TF Says Ishmael
JBF Goldmember 1,492 posts Likes: 1 Joined Dec 2005 Location: Lexington, KY More info | Jan 28, 2009 20:07 | #6 what other restrictions will one encounter by using nikon lens on a canon body? Is there a loss of a stop, like with a converter? Loss of AF? What other problems will occur? JBF
KenjiS "Holy crap its long!" More info | Jan 28, 2009 20:10 | #7 JBF wrote in post #7209138 what other restrictions will one encounter by using nikon lens on a canon body? Is there a loss of a stop, like with a converter? Loss of AF? What other problems will occur? Basically, No AF and no automatic diaphragm, meaning that the aperture you set on the aperture ring is what you see, its like running around with your DOF preview button held down [That can be an advantage or a disadvantage depending on subject] Gear, New and Old! RAW Club Member
dave_p Senior Member 675 posts Joined Feb 2008 Location: Kansas City More info | Jan 28, 2009 20:19 | #8 With a Nikon lens on a Canon body you lose autofocus and IS (or VR in Nikon lingo). It's just a very thin adapter ring. No light loss, etc. The cheap ones don't have electronics and the Canon can't give the metering info (you have to use Manual mode). The slightly more expensive ones have a little chip that fools the Canon into thinking there's a Canon lens attached, and it will thus provide metering. You basically can use that kind in Av or Manual mode, and IIRC certain metering modes work much better than others. I believe both kinds of rings will give a focus confirmation when the lens is focused correctly on the subject. Worst case is that the chip breaks off when you're using it or the entire ring breaks. Hasn't happened to me yet, but that was the worst horror story I found when doing research. Look on eBay for "Nikon EOS adapter". Do a Google search for more info, there's tons of it out there.
Hogloff Cream of the Crop 7,606 posts Likes: 416 Joined Apr 2003 Location: British Columbia More info | Jan 28, 2009 20:31 | #9 Permanent banYeh, thats the ticket. We would be eating right out of Canon's hands with no competion to improve their cameras and drive the price down. Good idea.
S.Horton worship my useful and insightful comments More info | Jan 28, 2009 20:52 | #10 Sony. Sam - TF Says Ishmael
KenjiS "Holy crap its long!" More info | Jan 28, 2009 22:04 | #11 dave_p wrote in post #7209237 With a Nikon lens on a Canon body you lose autofocus and IS (or VR in Nikon lingo). It's just a very thin adapter ring. No light loss, etc. The cheap ones don't have electronics and the Canon can't give the metering info (you have to use Manual mode). The slightly more expensive ones have a little chip that fools the Canon into thinking there's a Canon lens attached, and it will thus provide metering. You basically can use that kind in Av or Manual mode, and IIRC certain metering modes work much better than others. I believe both kinds of rings will give a focus confirmation when the lens is focused correctly on the subject. Worst case is that the chip breaks off when you're using it or the entire ring breaks. Hasn't happened to me yet, but that was the worst horror story I found when doing research. Look on eBay for "Nikon EOS adapter". Do a Google search for more info, there's tons of it out there. No you still get metering, just very simplistic metering Gear, New and Old! RAW Club Member
Nistelrooydude Goldmember 1,495 posts Joined Feb 2008 More info | Jan 28, 2009 22:13 | #12 I'm guessing "but" should be "buy", and that's the right idea.
jacobsen1 Cream of the Crop 9,629 posts Likes: 32 Joined Jan 2006 Location: Mt View, RI More info | you guys need to get out more.... My Gear List
Hogloff Cream of the Crop 7,606 posts Likes: 416 Joined Apr 2003 Location: British Columbia More info | Jan 28, 2009 22:43 | #14 Permanent banKenjiS wrote in post #7209984 No you still get metering, just very simplistic metering Take your lens off and notice it still meters :3 The biggest thing the little chip provides is AF confirm There is no AF. The chip provide confirmation that things are in focus, but you must manually focus the lens. There is nothing auto with the focus.
KenjiS "Holy crap its long!" More info | Jan 28, 2009 22:48 | #15 Hogloff wrote in post #7210257 There is no AF. The chip provide confirmation that things are in focus, but you must manually focus the lens. There is nothing auto with the focus. I know that, I meant Focus confirmation.. Gear, New and Old! RAW Club Member
| Latest registered member is semonsters 1509 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
