Thread started 24 Mar 2005 (Thursday) 09:46
New Cleaning Method for dSLR Sensors!
pradeep1
Joined Sep 2003
Mar 24, 2005 09:46 |  #1
Just saw this over at Steves Digicams:
http://www.intemos.com​/USA/dslrclean2.asp (external link)
Cost only about $3/cleaning, or about 1/2 cost of normal cleaning solutions.
pradeep1
Joined Sep 2003
Mar 24, 2005 23:48 |  #2
robertwgross
Joined Nov 2002
Mar 25, 2005 00:07 as a reply to  @ pradeep1's post |  #3
pradeep1 wrote:
I couldn't have said it any better.
What did you intend to say?
---Bob Gross---
Carzee
Mar 25, 2005 00:38 as a reply to  @ robertwgross's post |  #4
quote
1. Set your digital camera to sensor clean mode (enabling access to the sensor chamber).
2. Insert the DSLRClean™ stick so that the tip touches the sensor surface.
3. Apply pressure to the stick until the tip bends to a right-angle and forms a shoe on the
sensor. Figure 1
4. Move the DSLRClean™ stick around the sensor as shown in Figure 2.
5. Follow the sequence from 1 to 4 so that the DSLRClean™ stick returns to the starting
position.
6. Remove the DSLRClean™ stick from the chamber.
7. Reset the camera to normal operating mode.
For very dirty sensors, you may need two attempts to clean the sensor.
When you move the DSLRClean™ across the sensor, it will feel a little ‘sticky’. This is
intentional; the DSLRClean™ sticks are not sticky and contain no cleaning agents. This is the
result of the slight vacuum that is created by the DSLRClean™ stick.
Maybe we should wish for drive thru camera cleaning franchises in the metro areas... or some help; golfers have caddys, what do photographers have?
Having a bad day? Feeling down? Bantar Gebang Attitude Enhancement Images (external link)
pradeep1
Joined Sep 2003
Mar 25, 2005 09:53 as a reply to  @ robertwgross's post |  #5
---Bob Gross---
Oh nothing...I just bumped this up, because it fell off the front page in an hour or so that day it was posted. I am thinking of getting this product and trying it and was wondering if someone else had tried it already. Seems easier to use than a PEC pad with liquid cleaner.
Craig ­ Schwartz
Joined Jan 2005
Mar 25, 2005 14:23 as a reply to  @ pradeep1's post |  #6
So....has anyone used this product yet?
2,771 views & 0 likes for this thread, 4 members have posted to it.
1481 guests, 132 members online
