Thread started 31 Jan 2009 (Saturday) 11:29
So I have a bit of a dilemma (on walkaround lenses and telezooms)
KjellG
Jan 31, 2009 11:29 |  #1
Hello everyone :)
As the title suggest I have a bit of a dilemma regarding lenses. I'm planning on going on a trip around summer this year for maybe 2-6 weeks and my photogear is lacking some lenses on the telephotorange. I've got a 5D, 17-40 and a 50mm but no walkaround zoom or telezooms.
My budget is somewhat limited (I have maybe around $500-700 to spend on lenses) so I was thinking of getting a tamron 28-75 2.8 and a teleconverter 2X so I can have both walkaround and a moderate tele if I need it. But I'm thinking 28-75 isn't a big range since I'm wanting to do streetphoto and such, and the Canon EF 28-135 is - from what I've seen - not the best choice for IQ, and the Canon 24-105 is too expensive.
So, what's a good idea? The 28-75 2.8 and a teleconverter or something else?
Thanks in advance.
Some mornings, it's just not worth chewing through the leather straps.
-Emo Phillips
hypertech
Jan 31, 2009 11:46 |  #2
The 70-200 f/4 goes for about $500 used on here quite a bit. I think that would be my choice under those criteria.
Canon 5Dm2, 50D, XSi (450D), 580 EX IIx2
24-105mm f/4L IS, 70-200mm f/2.8L IS, 100mm f/2.8 Macro, 50mm f/1.4, 18-55mm IS, Tokina 116
www.reflectivecanvas.c​om (external link)
erkkimies
Jan 31, 2009 11:50 |  #3
KjellG wrote in post #7226665 (external link)
Hello everyone :)
Thanks in advance.
I think that 28-75 2.8 And the teleconverter would be actually pretty good
CountryBoy
"Tired of Goldmember label"
Jan 31, 2009 12:04 |  #4
Will the Tamron even work with a teleconverter ?
Anyway , with a 2x converter, i doubt if IQ would be very good.
Hi
KjellG
Jan 31, 2009 12:36 |  #5
^ From what I've heard it should work. I'm not sure about the IQ degradation because I haven't studied it so much.
I thought about the 70-200/4 too but then I have no walkaroundlense really. Unless I get both but that's above my budget =/
-Emo Phillips
Eagle
Gallery: 58 photos
Jan 31, 2009 14:37 as a reply to  @ KjellG's post |  #6
Get the 28-135, it's a great walk around. And check the shots out in the lens sticky for it, you'll be surprised.
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
KjellG
Jan 31, 2009 15:10 |  #7
The test shots I've seen are pretty crisp, but will it hold up when it comes to printing images? Like big images? I was hoping to have some exhibitions eventually and I'd hate it if the pics were of too poor quality for printing.
It's so low-priced I have to wonder why, especially since it's both IS and USM. Maybe it's just build quality?
-Emo Phillips
toxic
Jan 31, 2009 15:32 |  #8
^ its 'cause it's a kit lens.
a 28-75 with 2x tc is not gonna be sharp. Either try the 28-135 and see how you like it, or shell out the money for the 24-105.
TurboDean
Jan 31, 2009 16:25 as a reply to  @ KjellG's post |  #9
Are you willing to carry a lens? The 17-40 is relatively small, so if you had another smallish telephoto lens, would that do? IMHO, I would not count on the tammy + 2x TC to produce acceptable results.
For a smaller tele, I suggest the Canon 70-210/3.5-4.5 USM, if you can find one.
Relatively compact for its range (~2.9" x 4.8" at its shortest), metal lens mount, a large turn a ring to zoom (no push/pull), non-rotating front lens element, easily affordable 58 mm filters. One of the biggest pluses for me was the super fast, quiet, and accurate ring USM focusing motor and FTM. Optics wise it was very nice up to150mm, but still perfectly reasonable at 210 with good support (no IS, mind you!).
Reviews I found when I was looking at theis lens originally: mir.com (external link), emedia.leeward.hawaii.​edu (external link), photo.net (external link)
I sold mine (~$250) it to pay for a 100-300/4.5-5.6, because at the time I was using a 17-85 and though the 100-300 would make for a better travel package. Now that I use my 17-55 (closer to your 17-40), a telephoto starting at 70mm makes for a better package, IMO.
Dean
~40D based GEAR~
~Smugmug~ (external link)
JeffreyG
Gallery: 42 photos
Jan 31, 2009 17:40 |  #10
KjellG wrote in post #7227654 (external link)
Worrying about the IQ of the 28-135 while planning to try and use any wide angle zoom with a 2X TC strikes my as a major disconnect. The odds of a wide angle zoom + TC being acceptable is poor. You can at least count on the 28-135 alone to be acceptable.
My first choice would be to add the 70-200/4 and use a two-lens kit (17-40 + 70-200). Swapping between these two lenses would certainly be no more cumbersome than swapping in and out a TC, and I guarantee the 70-200 is much better than any 24-XX lens with a TC on it.
My second choice would be to add a single solution like the 28-135.
soxfan356
Jan 31, 2009 17:51 |  #11
70-300 IS is pretty good
-Dan
Canon 40d, 28-135 IS, 70-300 IS, 100-400L IS, Sigma 10-20, 430exII
My Flickr (external link)
Jeff81
Jan 31, 2009 17:54 |  #12
JeffreyG wrote in post #7228405 (external link)
I agree. I think thats you're best choice. You'll have a gap, but you can foot zoom and it won't be that big of a deal.
6D | Canon 24-105L f/4 IS, Sigma 50 f/1.4 Art, Canon 85 f/1.8
Feedback
khall
Jan 31, 2009 18:11 |  #13
Use your 50mm as your walk around lens. If you need a wider lens put your 17-40mm on. As others have suggested look for a secondhand 70-200mm which hopefully would come in your 500-700 dollar price range.
Have a nice holiday.
YNWA.
TurboDean
Jan 31, 2009 20:15 as a reply to  @ khall's post |  #14
70-200 is a good one, but cumbersome if looking to go light. I typically travel with the 17-55 and 70-200/4, but if I know I'm not going to packing my bag around, I slip the little 100-300 into a jacket pocket.
I sometimes wish I still had the 70-210/3.5-4.5 to go with the 17-55. Hmm... how much do I miss it... :)
Dean
~40D based GEAR~
carpenterken
Jan 31, 2009 21:30 |  #15
I have to agree her also. A 70-200 4.0 goes for $500 (used) all day long.
Although I don't get the bad rap the 28-135 gets. I have this lens and don't use it much based on all the bad raps. But, every time I put it on, I'm amassed at the IQ I get out of it.
These two candid type shots (both with little or no pp) where taken with the 28-135 #1 with the 40D and #2 (me by the way) with the 1D
#1
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i221.photobucke​t.com …istaken/Fish/IM​G_6598.jpg (external link)
#2
http://i221.photobucke​t.com …istaken/Fish/B8​6G7412.jpg (external link)
I do believe the 24-104 would be nicer, but it's 3x the cost.
Canon, 1D2n, 40D, 100-400L, 70-200 2.8, 28-135is, 17-40L, 85 1.8, 50 1.8, 1.4 tc, 430ex, 580ex. set of Radio Poppers, and wanting more.
1,972 views & 0 likes for this thread
Latest registered member is Chris Parrish
903 guests, 225 members online
