Thread started 01 Feb 2009 (Sunday) 04:15
Questions about ExifTool
lsquare
Feb 01, 2009 04:15 |  #1
I'm just wondering how many people here uses ExifTool with one of the GUIs available? If so, which GUIs do you recommend? I find the command-line feature of the ExifTool itself is too complicated for me to use. I want to use the tool to adjust the capture time of my RAW files.
http://www.sno.phy.que​ensu.ca/~phil/exiftool​/ (external link)
Are the changes made by ExifTool recognized in other programs like Adobe Bridge CS4/Photoshop CS4?
tim
Light Bringer
Feb 01, 2009 15:43 |  #2
AFAIK you can't change RAW times using EXIFTool. Bibble does it, so does Lightroom. Google will tell you more.
lsquare
Feb 01, 2009 16:57 |  #3
tim wrote in post #7233762 (external link)
On EXIFTool's page, this is one of the highlighted feature:
"Shifts date/time values (external link) to fix timestamps in images"
Have you tried it in the latest version?
I do have LR, but the problem is I'm not sure if the changes to the RAW capture time is permanate. I also don't like the idea of importing the pictures to make the changes which is why I'm looking for a different solution.
GSansoucie
Feb 01, 2009 17:45 |  #4
I used ExifTool command line only. I could have sworn I've adjusted the date/times of some Raw files in the past. I will take a peek at some of my scripts.
-=Glen=-
Flickr Stream (external link)
Check out my 2010 PaD (external link)
http://www.pbase.com/g​sansoucie (external link)
GSansoucie
Feb 01, 2009 18:07 |  #5
OK, the command line works fine.
Had I just followed your link above, I would have been done in 20 seconds...
You posted a link to the offset datetime function (put a + or a - in the date/time). You can specify an exact date time as well.
exiftool "-DateTimeOriginal=2008:​10:30 6:05:13" _MG_1931.CR2
I tried the above line on a copy of a raw file and then checked the exif data after and it worked fine.
Date/Time Original : 2008:10:30 05:13:00
Note, that if you want to set the Create Date as well, you need another parameter:
exiftool "-CreateDate=2008:10:30 6:05:13" _MG_1931.CR2
Create Date : 2008:10:30 05:13:00
Soooo.
The command line to use is:
exiftool "-CreateDate=2008:10:30 6:05:13" "-DateTimeOriginal=2008:​10:30 6:05:13" _MG_1931.CR2
Of course, you would put in the actual date/time in place of the date time I chose. You would also specify the actual filename.
If you want to apply the same date/time to all the raw files in your folder, use "-ext .cr2 ." in place of the actual filename (please note that final dot.
By default the above commands will save the original file as 'filename.original' which can get confusing. If you have faith in exiftool, you can specifiy '-overwrite_original' which will eliminate that 'filename.original' nonsense.
Hope this helps.
-=Glen=-
tim
Light Bringer
Feb 01, 2009 18:13 |  #6
lsquare wrote in post #7234172 (external link)
Interesting, didn't know it worked on raw files, thanks :)
lsquare
Feb 01, 2009 18:49 |  #7
GSansoucie wrote in post #7234552 (external link)
Soooo.
Hope this helps.
Thanks a lot for the detailed post! I feel intimiated by the command-line only programs. Have you used any of the GUI front-ends before?
When you changed the capture date, did the modification date changed as well?
What's the difference between the capture and create dates? Are both dates filled out in the Exif when the file is created within the camera?
GSansoucie
Feb 01, 2009 19:03 |  #8
lsquare wrote in post #7234774 (external link)
I have not tried any of the GUI front ends, sorry can't help you there.
"Modification Date" is ambigious:
File modification date will change to the date time that I ran exiftool, however, there is a way to change the file's modification date using exiftool (I run this script a lot when scanning in images).
exiftool "-DateTimeOriginal>FileModifyDate" _MG_1931.CR2
This above command is setting the actual File's Modification Date/Time to whatever the Exif DateTimeOriginal is set to.
(I'm on a Mac, Windows Dir will be a tad bit different)
-rw-r--r-- 1 glen staff 12367600 Oct 30 2006 _MG_1931.CR2
If you mean the Exif Modification Date, you just specify that tag on the command line:
exiftool "-ModifyDate=2006:10:30 6:05:13" _MG_1931.CR2
Modify Date : 2006:10:30 05:13:00
You can add all of those separate commands together on a single command line to make things easier.
From what I can tell, yes.
FYI: If you are ever bored and want to know what tags you can set, you can run "exiftool -list", it is a large list. I usually pipe this to a text file and then open the text file whenever I forget a tag.
Also, I keep a running text file called "Exiftool What Works for me.txt" and I paste in various command line options & descriptions that I know work. I always consult this file to see if I have either tried something or if I need to get something done that isn't already in a script (or drop action) somewhere.
-=Glen=-
lsquare
Feb 07, 2009 02:51 as a reply to  @ GSansoucie's post |  #9
I know this may be a bit dumb to ask, but I'm still hoping someone have tried out ExifTool GUI.
http://freeweb.siol.ne​t …foto/exif/exift​oolgui.htm (external link)
From the screenshot, it seems like I just need to set the "shift amount" and as long as those date and time fields are checked, then when I press "execute" the time on the EXIF will change?
AntonLargiader
Feb 05, 2023 12:39 |  #10
I'm trying to copy one value to another using ExifTool on my Mac. Specifically trying to put the "Shutter mode" value into the "Comments" field. I've tried the following but it's not working.
Shutter mode is available in the RAW:
[Track4] ShutterMode: Mechanical
I can access it with
exiftool -shuttermode 1.CR3
or with
exiftool -Track4:shuttermode 1.CR3
However, nothing I'm trying works to copy it.
exiftool -comment<shuttermode 1.CR3
-bash: shuttermode: No such file or directory
exiftool '-comment<shuttermode' 1.CR3
0 image files updated
1 image files unchanged
Using Track4:shuttermode doesn't change anything.
Any ideas? I've been following examples on the ExifTools forum but I'm out of ideas. Tried to sign up for their forum but gave up.
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
drsilver
Gallery: 904 photos
Post edited 9 months ago by drsilver. (3 edits in all)
Feb 05, 2023 17:10 |  #11
AntonLargiader wrote in post #19476349 (external link)
Try this.
exiftool '-comment<${shuttermode}' 1.CR3
The '<' operator redirects input from a file called shuttermode. You don't have that file. You need the ${} syntax to turn shuttermode into a variable and get its value.
That command only writes the value of the tag. If you want the tag name and the value, you could use this:
exiftool '-comment<SHUTTER MODE = ${shuttermode}' 1.CR3
Flickr (external link) : Instagram (web)] (external link)
AntonLargiader
Feb 05, 2023 18:34 as a reply to  @ drsilver's post |  #12
Thanks. Unfortunately that didn't work. Tried it with and without the Track4 part.
exiftool '-comment<${Track4:shuttermode}' 1.CR3
When I run the command I can see some sort of temp file appear in Finder underneath 1.CR3 and then it goes away. When I check the file the comment has not changed.
drsilver
Gallery: 904 photos
Feb 05, 2023 20:28 as a reply to  @ AntonLargiader's post |  #13
Hmmm? When I was playing with it earlier I was working on a .jpg file and it worked fine. Now when I try it against a .CR3 or .tif, no dice. I've never tried writing to an exif tag, so my knowledge just ran out.
The ${} syntax did get rid of your "no such file or directory" error.
AntonLargiader
Feb 06, 2023 09:46 |  #14
I think it's the apostrophes that fixed that. Seems that without them, the shell tries to interpret parts of the command as a shell command. There is some documentation of the ${} syntax at the exiftool site; seems that it should be avoided if possible but sometimes it's necessary.
The documentation is, I'm sure, quite thorough but for a newbie it's an impenetrable wall of stuff with no structure or index. It's inconceivable to me that no one has offered to write a user-friendly manual, so I assume it's not a welcome contribution. I'd be happy to take a stab at it once I learn my way around, though.
AntonLargiader
Feb 06, 2023 14:34 |  #15
Reading a bit more, it seems that ExifTool currently has limited abilities to write into CR3 files. According to a post of Phil's last month, the info in the Timed Metadata section cannot currently be modified. The origin of this problem is that the CR3 file is structured after a video file whereas the CR2 was structured after a TIFF file. Search for something like "CR3 edit exif" to find better descriptions.
I may still register and ask directly about this specific field, but I think the fact that it shows up in that "Track4" group suggests it's handled like video.
5,361 views & 1 like for this thread, 7 members have posted to it and it is followed by 3 members.
1064 guests, 104 members online
