Just want to make sure the DRebel XS plays well with the 420EX. Per Canon's specs, the XS works with any EX series flash, so my guess would be "yes." But, I wanted to ask you all... just for verification.
FlipsidE Goldmember 1,701 posts Joined Oct 2004 Location: South Carolina USA More info | Feb 01, 2009 15:26 | #1 Just want to make sure the DRebel XS plays well with the 420EX. Per Canon's specs, the XS works with any EX series flash, so my guess would be "yes." But, I wanted to ask you all... just for verification. FlipsidE
Feb 01, 2009 15:38 | #2 Well the XT & XTI do so the XS should... EOS 6d, 7dMKII, Tokina 11-16, Tokina 16-28, Sigma 70-200mm F/2.8, Sigma 17-50 F/2.8, Canon 24-70mm F/2.8L, Canon 70-200 F/2.8L, Mixed Speedlites and other stuff.
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 01, 2009 17:10 | #3 FlipsidE wrote in post #7233649 Just want to make sure the DRebel XS plays well with the 420EX. Per Canon's specs, the XS works with any EX series flash, so my guess would be "yes." But, I wanted to ask you all... just for verification. The only issue I can think of which you might encounter with the 420EX is that its AF assist beam will probably not work will all the AF points. If you only use the center AF point, then it won't be an issue. But if you do move your AF points around depending on the composition, then just be aware of that limitation. ...Leo
| Latest registered member is semonsters 1676 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
