Thread started 01 Feb 2009 (Sunday) 16:07
How to make the 85L manual focus override work all the time
xenomorphic
"at least there are images..."
Feb 01, 2009 16:07 |  #1
For what it's worth (sorry if this was obvious to everyone but me):
I just got the 85L which turns out is a bit unconventional when it comes to manual focus override in that the manual/booklet states that you have to depress the shutter-release button half way to be able to use the manual focus ring. Turns out this is correct. I find it really strange. But it turns out it doesn't have to be that way, courtesy of custom function 4.1. and single shot AF mode.
When using Av mode + single shot AF I normally either
a) focus, then recompose and get my desired exposure setting from the final motif, or
b) capture my desired exposure setting by pointing the camera at an arbitrary area that has the right sort of light in it, then recompose and focus.
I use Custom Function 4 "Shutter/AE lock button" set to 1: "AE lock/AF" to split the AE lock from the AF so I can use separate buttons to control each. (This takes some getting used to, but I heartily recommend it - so much more control, IMHO).
A side-effect of this C.Func. setting appears to be that the 85L behaves as if AF is always half depressed - you can always turn the MF dial and have the lens actually change its focus as opposed to having to keep the shutter release button half depressed. If C.Func. 4.0 (default) is selected instead, the MF ring works according to the manual - i.e. not without shutter-release button.
The manual warns against focusing manually while "AF is active" - but I'm assuming this refers to the lens actually being in the process of refocusing using AF, as opposed to AF being switched on - after all, the manual goes on to say you can adjust focus with MF after you have achieved initial focus with AF - which in a sense is what we're talking about here.
James
Reviews:
ThinkTank Pro Speed Belt and Modular set
ThinkTank Urban Disguise 60
Gear list
xarqi
Feb 01, 2009 16:34 |  #2
xenomorphic wrote in post #7233908 (external link)
Well, ^%$^ me! I'd say it was more than strange; "bizarre" is the word that comes to mind.
I've read lots of threads extolling the virtues of the 85L, but this little gem had not previously come to my attention. Thanks for posting.
msowsun
"approx 8mm"
Gallery: 18 photos
Feb 01, 2009 17:32 |  #3
http://photonotes.org …inner-faq/lenses.html#ftm (external link)
There are actually three different types of USM motors, although there’s no way to distinguish them apart by looking at them - the lenses are all simply marked “USM.” (use the PhotoNotes Lookup page to find which lens uses which motor)
The best USM motors are those used in most midrange and L series contemporary lenses - ring USM motors. A ring USM motor consists of two metal rings which vibrate at high frequencies, resulting in rotational energy. Full-time manual on a ring USM lens is easy - there’s a simple friction clutch which means you’re simply turning the whole motor by hand when you rotate the focus ring. This means you can focus the lens manually at any time, even if the camera is turned off or the lens isn’t attached to a camera.
The second type of USM is the earliest design, and seen only on a few older lens designs and some longer telephotos. These are electronic focus ring USM lenses which can only focus manually when the camera is actually turned on. This is because turning the focus ring sends electronic commands to the lens motor, ordering it to rotate. The following lenses are old-style electronic full-time manual USM lenses:
EF 50mm 1.0 L USM
EF 85mm 1.2 L USM
EF 85mm 1.2 L USM II
EF 28-80mm 2.8-4 L USM
EF 200mm 1.8 L USM
EF 300mm 2.8 L USM
EF 400mm 2.8 L USM
EF 400mm 2.8 L II USM
EF 500mm 4.5 L USM
EF 600mm 4 L USM
EF 1200mm 5.6 L USM
Perry ­ Ge
Batteries? We don't need no...   . . . or cards.
Gallery: 83 photos
Feb 01, 2009 18:57 |  #4
Yup, that's right. You should have focus set to the * button anyway :p so the 85L is just encouraging good behaviour.
Perry | www.perryge.com (external link) | flickr (external link) | C&C always welcome | Market Feedback & Gear | Sharpening sticky | Perspective sticky
KenjiS
"Holy crap its long!"
Gallery: 622 photos
Feb 01, 2009 20:30 |  #5
perryge wrote in post #7234805 (external link)
I hear this all the time, but why?
Deviantart (external link)
Perry ­ Ge
Gallery: 83 photos
Feb 01, 2009 20:33 |  #6
KenjiS wrote in post #7235324 (external link)
https://photography-on-the.net …php?p=5141381&p​ostcount=8
KenjiS
Gallery: 622 photos
Feb 01, 2009 20:35 |  #7
Makes sense
Will it fix my issue with FTM wherein ill have held the shutter button halfway, turned the focus ring to correct focus and then fully pressed, only to have the camera **** and say its not in focus anymore and lock my shutter? :/
Perry ­ Ge
Gallery: 83 photos
Feb 01, 2009 20:38 |  #8
YES it will fix that.
Gosh I've forgotten how idiotic the shutter half-press is. I still maintain what I said in that link - the back button focus should be default, with the option of switching to shutter half-press if you are a masochist.
KenjiS
Gallery: 622 photos
Feb 01, 2009 20:39 |  #9
perryge wrote in post #7235371 (external link)
....Then I guess im gonna get used to using 2 buttons
Perry ­ Ge
Gallery: 83 photos
Feb 01, 2009 20:40 |  #10
KenjiS wrote in post #7235378 (external link)
It'll take a few days, but after you get used to it you'll wonder wtf you were doing before you switched :p.
xenomorphic
Feb 02, 2009 03:52 |  #11
I second that. :)
Reviews:
Gear list
Shuko
Feb 02, 2009 03:52 |  #12
perryge wrote in post #7235385 (external link)
+1
Listen to the bunny!
www.miikajarvinen.fi (external link)
KenjiS
Gallery: 622 photos
Feb 02, 2009 09:57 |  #13
I just set it this morning..
its oddly coming very natural to me and i like it!
smorter
Feb 02, 2009 11:20 |  #14
I still use the old half press system...never really liked the * way
Wedding Photography Melbourneexternal link
Reviews: 85LII
Perry ­ Ge
Gallery: 83 photos
Feb 02, 2009 17:06 |  #15
No number six, the 85L is different. The MF ring doesn't allow full time manual normally, it's an electronic focus by wire design, so if the camera is off, the MF ring does nothing, and if you don't set back button to focus, there's no FTM, instead, MF is activated by the half-press.
4,275 views & 0 likes for this thread, 8 members have posted to it and it is followed by 2 members.
1707 guests, 170 members online
