Thread started 03 Feb 2009 (Tuesday) 07:19
Teleconverter versus Barlow?
Adrena1in
Feb 03, 2009 07:19 |  #1
Hi there, got a question for all those out there who use Barlows and/or Teleconverters for getting that extra bit of focal length...
A while back I had a cheap 2x teleconverter, which worked okay with my EF 75-300mm, EF 24-105mm and EF 18-55mm lenses. I never actually tried it with my scopes though, but instead always plumped for the Barlows.
My dad ended up with the Teleconverter, and I've just got another. The first was an "MC4", but this new one is an "MC7"...7 elements as opposed to 4 apparently...a better quality product apparently. So I thought I'd try it the other day.
I read somewhere that if the lens has a smaller aperture than f/4 that the auto-focus won't work. So I tried my 50mm f/1.8. Aimed at something 10 or 15 feet away, half-pressed my shutter button and the lens proceeded to focus all the way back and forth, very rapidly, without actually focussing on anything! I thought this seemed a bit odd.
I then hooked up my 400mm scope, aimed towards Venus, focussed the scope and pressed the shutter button, and got an error on the camera..."Can't communicate with lens", or something like that.
I read in a book somewhere that Teleconverters give better results than Barlows, but at the moment I strongly disagree. With the Canon EOS 450D is there a way to disable the camera-to-lens communication, so that it'll work when using a Teleconverter between the camera and a scope?
Thanks.
Canon EOS 450D, Sigma 18-200mm, Canon 50mm f/2.5 Macro, 2x TC, Revelation 12" f/5 Dobsonian, Mintron PD2285-EX webcam.
Adrena1in
Feb 04, 2009 13:16 |  #2
Does ANYone have a cheap EF Teleconverter that they've successfully used with a Canon lens? This Teleplus one I have doesn't work at all, so I'm hoping to get a Jessops one, like the first one I had.
dale65bama
Feb 05, 2009 15:59 as a reply to  @ Adrena1in's post |  #3
I do not think it is a problem with the teleconverter. I have a Canon Extender
EF 2X II. It work wonderfully well with my 200mm L f2.8. I have a Celestron Onyx 500mm f6.25 OTA that I wanted to extend to 1000mm with the converter. It reports the ERR 01, even with everything set to manual.
The question may be, "How can we "fool" the camera into thinking it is a manual converter?"
Dale
EOS 5D, Digital Rebel, EF-S 18-55mm Kit Lens; EF 200mm F2.8L, EF 100 f2.8 Macro, 500mm Celestron 80EDF; Sigma 24-70mm F2.8 EX DG macro; Cool POTN strap; BG-E1 Grip, CanoScan 8800f; RRS BH-40 Pro II on 3021BPRO legs
dale65bama
Feb 05, 2009 22:20 |  #4
Will probably buy a barlow!
Dale
Adrena1in
Feb 06, 2009 01:54 |  #5
dale65bama wrote in post #7262138 (external link)
The information I read about TCs being better than Barlows is probably quite old, before cameras got too "clever" for their own good.
Oh well, thanks for that, I'll just ditch the idea then.
Anyone want a Teleplus 2x MC7 Canon EF-fit Teleconverter?!  :o
EDIT: Ignore that, it would seem that blocking out the contacts on the TC will prevent the errors. I'll try it tonight.
Nighthound
Gallery: 224 photos
Best ofs: 24
Feb 06, 2009 10:43 |  #6
Thought I'd toss an option into the mix.
The TeleVue Powermates are excellent. I have the 2" 2x model with the T-ring adapter.
http://www.televue.com​/engine/page.asp?ID=42 (external link)
Steve
chris.bailey
Joined Jul 2003
Feb 06, 2009 13:05 |  #7
I tried the 1.4 Canon Telecon with my W/O ZS70 and could not achieve focus so gave up.
samsen
Feb 07, 2009 08:00 |  #8
If you are handy, clean tap those gold pins and use TC in manual mode. You will not get error 99 (Try only at your own risk. I accept no responsibility if something goes wrong!).
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
Adrena1in
Feb 08, 2009 12:37 |  #9
chris.bailey wrote in post #7268409 (external link)
Have yet to try it still, but how's the WO ZS 70, (changing the subject here somewhat)? I'm hoping to get a WO ZS myself any day now, and thinking of the 66mm. Widescreen Centre have them for £199, which I think is pretty good.
Adrena1in
Feb 10, 2009 05:44 |  #10
In case anyone's remotely interested, I taped over the connectors on my 2x TC last night, and it would then successfully take a photo with no lens attached, whereas before I was getting Err01 on the camera. Just in case anyone else was thinking of trying such a thing.
With my 2x Barlow, which is 2", and my 2x TC, I should still be able to get a fair bit of light in, but shoot at nearly 5000mm. Saturn...where are you...?
ahobden
Feb 10, 2009 07:51 |  #11
I have a WO ZS 66. Great Scope. You will need a WO flattener to get decent results though. The flattener also allows my 40D to connect directly to the Scope, with a mounting ring. Got mine from Ian King Imaging. Really helpful pleasent chap. Worth a call.
Adam
G10 | 40D | EF 17-40mm f/4L USM | EF 70-200mm f/2.8 L IS USM | EF 50mm f/1.8 II
www.adamhobdenweddings​.co.uk (external link) blog.adamhobden.com (external link) My flickr (external link)http://blog.adamhobden​.com/ (external link)
Adrena1in
Feb 11, 2009 10:05 |  #12
70mm f/6 and 0.8x Flattener ordered.
I hereby apologise to all in the UK, because cloudy skies are bound to appear when I receive it!!
ahobden
Feb 17, 2009 13:53 |  #13
How are you getting along with the new scope?
Adam
Adrena1in
Feb 18, 2009 03:17 |  #14
Haven't used it yet due to the weather. Plus I'm needing to do some jiggery pokery to get it attached to my EQ5 mount. It's a lovely piece of kit though...really solid, good quality in every respect...can't wait to give it its first light.
5,159 views & 0 likes for this thread, 6 members have posted to it.
1631 guests, 141 members online
