Thread started 03 Feb 2009 (Tuesday) 20:20
EOS 5D Mark II and EF-S 10-22 EFS/EF conversion
rage_rman
Feb 03, 2009 20:20 |  #1
Just got my 5D Mark II 2 days ago. I also did an EF conversion on my 10-22mm Lens. I don’t have my 40D any more and thought it would be sad to sell this lens. More pics to come.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://img.photobucket​.com …/v356/ragerman/​nEWcAN.jpg (external link)
Canon 5D / Canon 5D Mark II
EF 24-105mm f/4L IS USM, EF 70-200mm f/2.8L IS USM, EF 17-40mm f/4.0L USM, EF-S 10-22mm f/3.5-4.5 USM, EF 50mm f/1.8 II, EF 50mm f/2.5 Compact-Macro, Speedlite 580EX
http://www.rmedia.ca (external link)
AlphaChicken
Knot Hank
Feb 03, 2009 20:28 |  #2
:D I think you need to change your avatar. :D
looking forward to seeing some test shots/result shots... ;-)a
I am Henry. NOT Hank. And certainly not a length of rope tied in a knot. ;)
My family calls me Hen, but you can call me Chicken. See you out there!
|Deviant Art (external link)
|Facebook (external link)|Gear List
bacchanal
Feb 03, 2009 20:35 as a reply to  @ AlphaChicken's post |  #3
Awesome...looking forward to some test shots. ;)
rage_rman
Feb 03, 2009 20:38 |  #4
Ya can't wait to get out tomorrow and snap some pics.
vpnd
Feb 03, 2009 20:54 |  #5
10mm on a full frame? How does the conversion work? I haven't heard of that..?
Canon "Snappy".... Thanks Mom and Dad!
"I don't like to play dress up, or pet my gear. I like to shoot stuff and then print it and put it on my wall."
rage_rman
Feb 03, 2009 20:59 |  #6
I'll post pics up and what lens I used tomorrow.
eth3rton
Gallery: 27 photos
Feb 03, 2009 21:07 |  #7
Nice! Gonna post a tutorial?
rage_rman
Feb 03, 2009 21:10 |  #8
Here is a crappy how to remove the EF and EF-S baffles (this is at your own risk!) I saw it somewhere and copied it for later use.
1. You will need a small Phillips screwdriver screw driver
2. There’s a raised screw on the side of the metal lens mount about 15 mm to the left of the electrical contacts that retains the baffle.
Undo it. (Don’t undo the two inset screws that retain the electrical contacts.)
3. Remove the four screws on the rim of the lens mount that hold the lens mount to the lens body. (don‘t hold the lens by just its barrel once you’ve removed these four screws)
4. Gently lift one side of the lens mount upwards at the point furthest from the electrical contacts, enough to be able to get your fingers underneath. (Note: the lens mount won't move much near the electrical contact owing to connecting wires – so don't try pulling the lens mount off.)
5. Push the baffle out of the lens mount from underneath whilst holding the lens mount firmly, taking care not to pull out the wires (note: the wires are firmly attached, so this would take some force). The baffle’s held in (not very firmly) by four plastic clips, and will ping out when pushed from behind.
6. Reassemble. (Note: if you’re replacing the baffle with an EF one, this can be added after reassembling the lens).
MinhThien
Feb 03, 2009 23:09 |  #9
Op, you should just get the 17-40 instead or even better 16-35:)! I think the 10-22 will be like super super wide on ff?
Eric
5D IV | 35L II | 200L IS | 85L II | 430EX | 190CXPRO4 | 498RC2 | TT Streetwalker Roller| TT Restro 7 | F-stop Kenti |
AmpedPhoto
Feb 04, 2009 00:18 |  #10
guys please please be carful....I did this as practice to my 28-135...no issues...did it to the 17-55 put to much pressure and just pulled then contacts of the lens...My fault completely...I only blame myself :( almost as bad as dropping the lens...Looks like it might be time to bust out the soldering iron or send it in to canon...epic fail
Canon 5D Mark II (x2), 30D, 40D, G10, 70-200 F4 IS (x2), 16-35 f2.8 L, 50mm 1.4, 430 EX II (x2), 580 EX II Tamron 28-75 F2.8 (x2), Tonkia 12-24 F4, 10-18 Fisheye, Full studio with some light :)
AmpedPhoto.com (external link)
Zethar
Gallery: 27 photos
Feb 04, 2009 06:53 |  #11
Does the shutter fire correctly? I was under the impression that this was not physically possible due to the rear element of the lens sitting too far into the camera body and thus interfere with the operation of the shutter mechanism. You're brave - let us know how it works.
1DX, 1DIV, 5DIII, A7RII, RX1RII, 14 2.8L II, 35 1.4L, 50 1.2L, 85 1.2L II, 135 2L, 16-35 2.8L II, 24-105 4L IS, 24-70 2.8L, 70-200 2.8L IS II, 300 2.8L, 400 5.6L, IS, 800 5.6L IS
rdompor
Feb 04, 2009 07:57 |  #12
I'm pretty sure he still can't use it at 10mm. All he did was remove the baffle that prevents the lens from being mounted, but the reason that baffle is there is because the rear element of the lens sticks too far out from the mount and can be hit by the mirror when placed at 10mm. On my 1D, I can set the lens as far down as 11-12mm before I have a problem with the mirror hitting the rear element. With the 5D's larger mirror, I suspect you'll need to be around 13-14mm to clear it.
Ramon
ULTRAMONTAGNE (external link)
Website (external link)
Hermeto
Feb 04, 2009 08:11 |  #13
rdompor wrote in post #7251580 (external link)
That's my understanding too.
It should be usable from 13mm up, but not wider..
Jethro790
Feb 04, 2009 09:48 as a reply to  @ Hermeto's post |  #14
I do not see why you wouldn't turn that 10-22 into 5 or 6 hundy and just buy a nice 16-35? But I admit, I want to see some photos.
If you must know...
Synenergy52
Feb 04, 2009 09:57 |  #15
The 28-135 is an EF lens... why did you do this? Sorry if I misunderstood
AmpedPhoto wrote in post #7250273 (external link)
"Shooting the 5D is like shooting a view camera: its a pain, but the results are why you do it." - Ken Rockwell :p
My Photo Blog (external link)
5D| 17-40L | 50 1.4 | 430EX | SD780 IS P&S
16,444 views & 0 likes for this thread
Latest registered member is LYM
507 guests, 371 members online
