Thread started 04 Feb 2009 (Wednesday) 15:19
Flash Bracket with 500mm
britt777
Joined Jan 2005
Feb 04, 2009 15:19 |  #1
Hi all, I have the strobo frame 350 quick flip bracket. I am wondering if this is a good bracket to use or if I should invest in the Wimberly f-1, f-9 or the Really Right Stuff B-91? I am going to be using with the wimberly head V2 and 500mm?
Thanks Brittany
Brittany
www.shutterprophotogra​phy.com (external link)
PacAce
Joined Feb 2003
Feb 04, 2009 16:05 |  #2
The F9 with an extension will get the flash up high where you want it to reduce the "red-eye" effect (or whatever color the subject you shoot with the 500 has). The F9 attaches to the Wimberley head so that the flash stays with the head when swapping lenses. The drawback with that is that if you want to handhold your 500 ( :shock: ) the flash won't come with it. :) (Although, come to think of it, if you do want to handhold your 500, you will be able to mount the F9 on foot of the tripod collar of the lens.)
...Leo
Bubble
Feb 04, 2009 16:08 |  #3
B-91 will BARELY have enough clearance for it. I suggest to go with Wimberley.
Canon 5D II, 7D | 16-35L II | 24-70L | 24-105L | 50L | 85L II |  iMac 27 | Redrock Micro DSLR Cinema Bundle | Elinchrom Ranger RX-AS Kit| Elinchrom Digital Style 1200RX/600RX | Turbo SC |
britt777
Joined Jan 2005
Feb 15, 2009 11:51 |  #4
Still need some suggestions on a flash bracket for the 500mm. I am using the v2 wimberly head.
I am looking at the wimberly F1 and F9 bracket.
Anyone using the 500mm with flash bracket, please let me know what your using and how you like it.
Thanks in advance!
Brittany
scot079
Feb 15, 2009 11:57 |  #5
here's a pic(hi-quality:-)) of the f-9. Like Leo and Bubble said, it's the one you want.
IMAGE: http://i170.photobucket.com/albums/u264/scot079/jpeg_reencoded.jpg
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
britt777
Joined Jan 2005
Feb 15, 2009 12:21 |  #6
Thanks Tim, I read this on Arthur Morris site :
F-9 Wimberley Head Flash Bracket
(for Wimberley Head Version II)
This bracket consists of modules M3 & M9. It attaches directly to the Arca-Swiss style dovetail on the swinging arm of the Wimberley Head Version II. Since it is attached to the head and not your lens, it remains in place when you switch lenses. The bracket folds flat for easy storage.
The F-9 bracket has been designed to clamp to both the swing arm of the V-2 Wimberley and to the plates so it can be used when working on the ground or from the car, but I still prefer the F-1 to the F-9 in these situations as it gives you more flexibility.
I would like more flexibility.
Brittany
PacAce
Joined Feb 2003
Feb 15, 2009 16:03 |  #7
britt777 wrote in post #7330026 (external link)
They're both equally flexible. It all depends on what type of flexibility you want. If you have an L-plate for your camera, the F-9 provides a little more flexibility than the F-1 does because the F-9 can be mounted on the L-plate and allow the use of any lens you have. The F-1, by itself, can only be mounted on the plate attached to the foot of a lens tripod collar so you won't be able to use the it with regular lenses unless you get the M-8 perpendicular plate ($85).
If you don't have an L-plate, then you'd need to get the M-2 upright ($44) for the F-9 but that's still cheaper than the M-8 that would be required for the F-1.
Anyway, that's just my take on it. The reason I like the F-9 so much is because the M-9 that comes with it is so flexible to use. Most clamps mount perpendicular to the plate. That's why the F-1, when mounted to the camera plate, requires the M-8 perpendicular plate to realign the F-1. The clamp on the M-9 can be pivoted so that you can mount it to a plate in parallel, or perpendicular to the plate, or at any angle in-between.
...Leo
britt777
Joined Jan 2005
Feb 15, 2009 19:05 |  #8
Thank you Leo for the info. Decisions decisions
Brittany
blackpearl
Jan 10, 2011 09:31 |  #9
looking to mount the 580ex to the 500mm f/4 so I can use it handheld...thoughts?
gear bag> 7d,canon ts2i, 500mm f/4L is usm, 100-400mm f/4-5.6L is usm, 70-200mm f/4L, 70-300 IS USM, 17-55 IS USM, 28-135mm, 500macro, singh ray and b+w filters,580 exII, Better Beamer, gitzo 2541 and 3541 tripods, beanbag, naturscapes skimmer pod, Lowepro mini trekker, Drake Pro camera bag, Gura Gear Kiboko Bag
PacAce
Joined Feb 2003
Jan 10, 2011 09:58 |  #10
blackpearl wrote in post #11610287 (external link)
What kind of plate are you using on the lens and on the camera? There are a few Wimberley and RRS options you can go with depending on what suits you best. I'm sure Kirk Enterprises also has a few flash brackets that'll all you to handhold your 500 f/4.
...Leo
5,268 views & 0 likes for this thread, 5 members have posted to it.
640 guests, 122 members online
