Thread started 07 Feb 2009 (Saturday) 17:41
sRGB or Adobe RGB ?
PaintballPhotography.com
Feb 07, 2009 17:41 |  #1
sRGB or Adobe RGB ?
Just wondering which of these two color space settings people are using and why? ;)
Gary Baum
www.paintballphotograp​hy.com (external link)
NPPL 2009 Photographer of the Year
NXL Media Liaison
SportsShooter Member
Hermeto
Feb 07, 2009 17:51 |  #2
Use sRGB if most of your pictures are going to be presented on the Web, or if you plan to print them in the lab.
If you have photo printer and want to print most of your pictures yourself, use Adobe RGB.
MinhThien
Feb 07, 2009 17:55 |  #3
Hermeto wrote in post #7276390 (external link)
I was told opposite of this! :confused: I don't like to print my photo at home! I prefer the professional to do it! So I should be using SRGB?
Eric
R6 | rf50L | rf85L DS | ef200L IS | 470ex | 190CXPRO4 | 498RC2 | TT Streetwalker Roller| TT Restro 7 | F-stop Kenti |
Hermeto
Feb 07, 2009 17:57 |  #4
Most of the labs will require sRGB, but you should always check..
René ­ Damkot
Feb 09, 2009 06:04 |  #5
sRGB for web and send off.
AdobeRGB when you know why not to use sRGB ;)
Have a read in a few of the links in the link from my sig...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
lungdoc
Feb 09, 2009 06:33 |  #6
If you don't already know the answer....sRGB :)
I use sRGB as I print at Costco and display on web.
Mark
My Smugmug (external link) Eos 7D, Canon G1X II, Canon 15-85 IS, Canon 17-85 IS, Sigma 100-300 EX IF HSM, Canon 50mm 1.8, Canon 85mm 1.8, Canon 100mm 2.8 Macro, Sigma 50-150 2.8, Sigma 1.4 EX DG , Sigma 24-70 F2.8 DG Macro, Canon EF-S 10-22, Canon 430EX,
Az2Africa
Feb 09, 2009 07:03 |  #7
I shoot in Adobe RGB and process in ProPhotoRGB since I do all my own printing. Even if I didn't, I would still us AdobeRGB and just convert the profile in Photoshop if I wanted to use it for the web or an outside lab.
"If you're not living on the edge. You're taking up too much room !"
My Gear Arizona's POTN Flickr Gallery (external link)
John ­ E
Feb 09, 2009 07:20 |  #8
If I print raw directly from Lightroom, does the program itself convert the picture to sRGB or Abobe RGB 1998 before sending to the printer?
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
René ­ Damkot
Feb 09, 2009 07:49 |  #9
Az2Africa wrote in post #7286530 (external link)
Since you "shoot in AdobeRGB", I presume you shoot jpg?
You realise that the conversion to ProPhotoRGB brings no benefit?
Lowner
"I'm the original idiot"
Feb 09, 2009 08:51 |  #10
Slightly off topic so I apologise in advance. But Rene has raised something I've thought for a while.
That is, what advantage is a wide gamut monitor to us photographers? 99.99% of my output is print with a bit sent to zenfolio link below. So I use aRGB and sRGB and don't understand what benefit there could be from showing gamuts wider than I can ever see. What am I missing here?
Richard
René ­ Damkot
Feb 09, 2009 09:07 |  #11
Inkjet printers can print colors that fall outside sRGB gamut.
That's why, for a AdobeRGB workflow, a wide gamut monitor can be an advantage.
If your workflow and output is sRGB there's no advantage IMO, and there are possible disadvantages.
Az2Africa
Feb 09, 2009 09:11 |  #12
I realize the the camera setting only applies to jpeg. I seldom shoot jpeg, but when I do, my camera is set to AdobeRGB.
As far as shooting in raw and processing in ProPhotoRGB, there is a larger gamut and more to draw from. I use a decent monitor and printer and wish to take advantage of as much information as possible.
Lowner
Feb 09, 2009 09:25 |  #13
Az2Africa and Rene,
Thanks for the answers. I suppose my belief stems from the fact that I've never seen any real visual difference in prints made from either sRGB and aRGB. I say visual, because I am aware that there is an actual difference, but it is extremely subtle.
So when using a wide gamut monitor and something like ProPhotoRGB, is there a dramatic change when the image is softproofed prior to printing?
Richard
basroil
Feb 09, 2009 09:31 |  #14
Use RAW for everything, and when it needs to be a tiff, use ProPhoto. For PSD, LAB. 99% of my output files though are in sRGB simply because they go online.
Az2Africa
Feb 09, 2009 13:59 |  #15
Lowner wrote in post #7287205 (external link)
Az2Africa and Rene,
When the monitor is calbrated and the custom profile for the paper used is done right, I see very little change when softproofing. They say it's best to look away and then hit the botton and then look at the image to see if you notice the difference. At most I may add a tiny bit of saturation. Usually nothing if everything is set right.
Some papers however; even after making a profile do shift for some reason and require a tweak in the softproof. I notice it more with printing on canvas. Breathing Color canvas seems to need the least. For me anyway.
2,313 views & 0 likes for this thread, 9 members have posted to it.
sRGB or Adobe RGB ?
1228 guests, 110 members online
