I was going to comment in regards to Robert's post and baccanel beat me to it. Baccanel hit the nail on the head there...typically you want the ambiance of the stage lighting to show thru, particularly with "band" shots. Flooding the shot with flash just does not look "natural" for these types of shots at all and with all due respect to Robert and his expertise (which normally I'm more than happy to defer to), that was poor advice.
Not that I've shot a lot of these types of situations, but whenever I do, I try to avoid using flash. In my mind, the key to getting good stage shots like this is simply a fast lens and a camera that does reasonably well at higher ISO's so that you can keep the shutter speeds up a bit. In that regard, -if- a flash has to be used, I think the OP did the right thing by bouncing it. If anything I thing I would have dialed back the power a bit.
In regards to the shots themselves, I do agree with Robert in regards to the third shot there of the two chicks dancing...that is simply splendid and certainly the best of the lot. I'm not normally a fan of desaturations/b&w but I think it works very well for this shot. I also think that the last shot is really good there too. I'm not too crazy about the two shots where the performer's heads are down...in my mind getting good band shots requires some facial emotion as the shots otherwise tend to be rather static and when you can't see the faces...you get my point. Which leads me to the second shot there....
Ok...I will admit that I am all for "grimacing musically", but that is simply NOT a flattering expression on the guitar players face there (the guy playing the Schector)! I think the OP nailed the focus and otherwise I think it's a good shot, but looking at it I really feel like I should be giving that poor guy a bottle of Malox or something! As a musician I know that rock & roll ain't supposed to be "pretty" but I really think I would have gotten a different shot of the guy to post. This is most certainly just my opinion and should only be taken as such but...yikes, I say! LOL!
The one other thing I would add is that I think the OP should have maybe used even more "low angles". From the looks of things here, it doesn't appear that there was much of a stage at all there (as a musician, this is something I've ran into with bar gigs myself). The first and second shots look as though they were taken while the OP was standing on a chair or something. The reason I mention this is that in my opinion at least, shots of musicians (even local unknown talent) typically works better when the photographer can create a "larger than life" feel with the shot. Going back to the last shot for example, here it was shot from a low angle and creates something of the "guitar god" illusion....very preferable to the angle the first shot was taken at.
Over-all I think the op did a pretty good job here and is certainly on the right track. Performing shots can sometimes be hit or miss to begin with so all things considered, there were a couple of really good shots here.
Alrighty, just my $.02 worth,
Jim
"It is horrifying that we have to fight our own government to save the environment. " - Ansel Adams
Walczak Photography - www.walczakphoto.izfree.com
