Thread started 09 Feb 2009 (Monday) 12:45
Cannot make 150K pic work
trailguy
Feb 09, 2009 12:45 |  #1
If I'm correct, the image max to attach is 150K, and when I downsize a 3484 X 2592 pixel, 25.5M shot to a 150K picture, it falls apart when viewed onscreen.
What am I doing wrong?
I've attached (I think) an image I downsize to 147K.
Thanks for any advice
Perfectionism is the highest form of self-abuse
"Best wide-angle lens? Two steps backward"
Ernst Hass 1952
AngryCorgi
-Bouncing Boy- a POTN peion
Location: Surrounded by bunnies, squirrels and a couple of crazy corgis in NoVA...
Feb 09, 2009 13:04 |  #2
If you are using photoshop, you can "save for web" and set your image file size limit as a criteria for suggesting quality of output.
AngryCorgi (external link) (aka Tom) ...Tools...
...Knowledge is knowing that a tomato is a fruit, Wisdom is knowing not to include it in a fruit salad...
Anke
Feb 09, 2009 13:08 |  #3
That image is 104k by the look of it.
What compression level are you saving at, 8 is fine for web use.
Anke
Anke
Feb 09, 2009 13:24 |  #4
Just to make sure you are looking at the size on disk rather than the document size, i.e. the uncompressed size in PS.
Anke
cdifoto
Don't get pissy with me
Feb 09, 2009 13:26 |  #5
You're never going to get a 3484 X 2592 image to look good at 150k. It needs to be 1024 on the long side for the forum anyway.
bryanlee1981
Feb 09, 2009 20:40 |  #6
Your best bet is to host your photo on a site such as flickr (external link) and then just link to it in your post.
EOS Rebel T3i
18-55 mm IS type II f/3.5-5.6
75-300 EF-S III f/4-5.6
55-250 mm f/4-5.6
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Feb 09, 2009 22:09 |  #7
Save you picture as you normally would...then get yourself Prish Image Resizer....resize to 1024 and you should be good to go. Download is located here.... http://prishcom.spaces​.live.com …A6A204ABDF15411​!128.entry (external link)
745 views & 0 likes for this thread, 6 members have posted to it.
2307 guests, 138 members online
