roger767 wrote in post #7301311
I think im gonna try too install XP 64, maybe that will run 10% to 20% faster. I know that XP 32 vs Vista 32 with 2gb RAM, XP was faster in Photoshop CS3.
Changing the OS won't make any difference.
I was working on mulitple 30D raw files and resulting 16bit TIFFs on a 2.6ghz Core 2 with 2GB of ram yesterday, and had no issues with performance.
Batch proccessing took longer than on my quad core, but I could do it, and use bridge or explorer at the same time.
Either your problems are imagined, or there could be something wrong with your hardware, or something running that shouldn't be.
The CPU hitting 100% is not an issue, even my quad core does that when working on something that are CPU intensive. All it means is the CPU's capacity is being fully utilised by what ever applications are running, and so things are happening as fast as possible.
Most of the filters in PS are RAM rather than proccessor intensive. If for some reason not all of the RAM is being used, or not being used properly by PS then you could get issues.
And some filters are so large and complex, that when working on larger files (and 10mp is getting up there, espeically if they are 16bit TIFF) then it doesn't matter how fast your computer is, there will be a time delay while they are processed.
Useing my quadcore with 4GB of ram, I just applied the surface blur to a 16bit TIFF from my 30D. It took about 20secs to finalise. But it is a VERY ram intensive process. However I was able to get using other applications at the same time with out any issues.
Had I tried it on my spare P4, or my old 2600 athalon, it would have slowed the systems right now, might have locked them up, or would have taken several minutes to complete.
Note, when I converted the image to 8bit, the filter was applied instantly.
Now note, running a Quadcore instead of the dual core, would make a noticable improvement.
I've worked on several dual core systems and quad core systems now, and there is deffinitly a noticable performance advantage to the quad cores.
BUT, for a simple, single task process, the dual cores are quite suitable for running photoshop and lightroom. It is only when you start running other applications at the same time, and doing lots of batch processing that the performance difference of the quad cores starts to become important.
If you could provide some real details, what file types, actual time it takes, etc, we might be able to help more.
