I really like this pictures. It was taken in Acadia but it was VERY foggy. I am trying to find a way to really make the water splash POP. I don't like the way i have it now. Is the a fruitess effort as there is to much white space.
bphillips330 Senior Member 640 posts Joined Oct 2006 Location: ohio More info | Feb 11, 2009 06:34 | #1 I really like this pictures. It was taken in Acadia but it was VERY foggy. I am trying to find a way to really make the water splash POP. I don't like the way i have it now. Is the a fruitess effort as there is to much white space.
jgrussell Looking around nervously 18,758 posts Likes: 14 Joined May 2008 Location: NJ USA More info | Feb 11, 2009 09:31 | #2 The unedited image is so small that any editing tends to create artifacts immediately. Is the original larger? -- jgr
Feb 11, 2009 11:40 | #3 yes. I shrunk it to post. I can post a larger vs. or put a link to it when i get home.
nosleep Member 45 posts Joined Jan 2009 More info | Feb 11, 2009 12:51 | #4 Do you have a Raw file? 30d | Tamron 28-75mm 2.8 | Olympus Zuiko 28mm 3.5
BeauHudspeth -Cool Title- More info | Feb 11, 2009 17:03 | #5 nosleep wrote in post #7304112 Do you have a Raw file? Correct. If you do, then there is (more then likely) hope! _______________
BeauHudspeth -Cool Title- More info | Feb 11, 2009 17:05 | #6 Also, negative space is not always a bad thing. If all else fails, you could to a 16:9 crop to remove some of the white area and still be using a fairly common aspect ratio. _______________
| Latest registered member is ANebinger 1192 guests, 182 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
