Thread started 11 Feb 2009 (Wednesday) 20:03
Battery question.
tmonatr
Feb 11, 2009 20:03 |  #1
Okay, all you battery experts. (Are you there, Tim?) I just received my LaCrosse BC-700 charger and have tested my sets of Duracell Nimh batteries I have been using (abusing?) with a 15-minute quick charger. The good news is my set of 2650mah units all showed a capacity from 2300 to 2600 mah. The bad news is my older set of 2400 mah has 3 showing around 1700mah, and 1 cell that is evidently shot because it is still in the discharge phase after 6hrs (about 12 hrs total including the initial charge phase of the test cycle) and the other 3 are already charged.
My questions:
1.Any hope for the defective cell? no big deal, but if I can get more out of it, great.
2. More importantly, I have a couple sets of the Maha Imedion AA's coming and would like to know the proper way to both initially and regularly charge them. Should I run the refrsh cycle right off the bat, or not since they are supposed to be precharged.:confused:
Tim
Bartender - "So, you guys are dictionary salesmen."
Roy Munson - "You would be punctilious in assuming that."
GSansoucie
Feb 11, 2009 20:28 |  #2
My take on bad cells: chuck 'em. All it takes is one bad cell in your pack, 3 'awesome' and one bad = no workie.
With that said, try popping the "bad cells" out and trying again. On my charger, I will actually get a reading of "null" for bad cells & those get moved to the trash.
Can't help yah on the Imedions, I'm an Eneloop convert (no charging necessary out of the package).
-=Glen=-
Flickr Stream (external link)
Check out my 2010 PaD (external link)
http://www.pbase.com/g​sansoucie (external link)
tmonatr
Feb 11, 2009 21:32 |  #3
Well, the bad cell is finally charging. Hopefully I can run the older set through the refresh cycle and revive them.
GSansoucie wrote in post #7307259 (external link)
The Imedions are Maha's version of the Eneloops. Precharged and low discharge. I know you can use them right out of the box, but for the ultimate life and performance from them, I was wondering what the proper procedure is. That was the reason for getting the smart charger.
Tim
ryant35
Gallery: 16 photos
Feb 11, 2009 23:03 |  #4
This reminds me that I need to get a multimeter from Radio Shack...
5DMK4, 7DMK2, 24-104mm f/4 L, 70-200mm f/2.8 IS II, 100-400mm f/4.5-5.6 IS MK2, 17-40mm f/4, 100mm f/2.8 Macro, 35mm f/1.4,1.4X & 2X TC III 580EXII
www.ryantorresphotogra​phy.com (external link)Photography Facebook Fan Page (external link)
1,044 views & 0 likes for this thread, 3 members have posted to it.
Battery question.
Latest registered member is heidiro
1239 guests, 110 members online
