Thread started 12 Feb 2009 (Thursday) 15:13
5D Mark II - Failures...
puggle
Feb 12, 2009 15:13 |  #1
I was seriously considering upgrading my 5D to a 5D Mark II until I read about these failures...
(click link, scroll down to "failures")
http://www.luminous-landscape.com …arctica-2009-worked.shtml (external link)
Anyone else experience 5D Mark II problems?
Puggle
Canon 1DXmkII, 5DmkIV, Sony A7rII, PhaseOne XF IQ100, PhaseOne 645DF+D
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Feb 12, 2009 15:19 |  #2
luminous-landscape wrote:
In all cases it appeared to be water or humidity damage
taking a non-weather sealed camera (of any make) and using it in a hostile environment is taking a chance of failure. I wouldn't be concerned if it were me.
TF posting: here :-)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Feb 12, 2009 15:23 as a reply to  @ joeseph's post |  #3
There's already a long thread on this (something like "Oh, oh, weather problems") but the short answer is: Nobody who has taken their 5D2 to Antarctica since then has any similar problems.
Nor are people in places like Canada and Sweden reporting such problems.
tharmsen
Feb 12, 2009 15:24 |  #4
I would say if you're going into a hostile environment, get a 1D.
Otherwise, right here at home the 5DMK2 is the ticket. :)
BigBlueDodge
Feb 12, 2009 15:25 |  #5
You're 5 days late on this. It's been talked about at great length in this thread
https://photography-on-the.net …highlight=5d+mk​ii+failure
Search is your friend....
David (aka BigBlueDodge)
Gear
puggle
Feb 12, 2009 15:25 |  #6
Sure, but they advertise it as weather resistant, don't they?
The article also said "not one Nikon was damaged" UGH!!
Puggle
beepclick
Feb 12, 2009 15:25 |  #7
Yeah, your 5D Classic will perform much better under the same conditions.
Gear https://photography-on-the.net/forum/showthre​ad.php?t=635450
bacchanal
Feb 12, 2009 15:28 as a reply to  @ joeseph's post |  #8
It has been suggested that moisture may build up between the body and the grip when using a grip...so probably best not to use the grip if in a wet, rainy environment. I believe this may be the case with the problems reported by LL.
I have had my camera lock up on me (flashed "busy" on top lcd), and I had to remove the battery to get it going again.
Another common "problem" that is often misdiagnosed is the dof preview button seems to be a bit easier to push while shooting than with the 5D. This can lead to the perception that the AF is intermittently not working.
DarthVader
There is no such thing as Title Fairy ever
Feb 12, 2009 15:31 |  #9
Either they had a bad batch, salt water, or user stupidity..
http://forums.dpreview​.com …rum=1032&messag​e=30972714 (external link)
Nikon/Fuji.
Gear is important but skills are very important :)
gjl711
Feb 12, 2009 15:34 |  #10
Well this is actually the second report of Canon doing badly in Antarctica and Nikon coming up roses. There was a very similar article last year or maybe the year before that's pretty much the same story. It's getting pretty clear that if your planing a trip to Antarctica, don't bring Canon cameras as they don't seem to do well in that environment.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
RDKirk
Joined May 2004
Feb 12, 2009 17:36 |  #11
puggle wrote in post #7312587 (external link)
Not seriously. "...the EOS 5D Mark II now has dust and water resistance that is almost equal to that of the EOS-1N—Canon’s top-of-the-line professional 35mm SLR for most of the 1990’s" isn't an enthusiastic endorsement, and that's the closest thing to a statement of actual weather performance that Canon has put into print.
JWright
Joined Dec 2004
Feb 12, 2009 18:02 as a reply to  @ RDKirk's post |  #12
Are you planning on taking your 5DII to Antarctica? If not, you should be ok...
John
syntrix
Feb 12, 2009 18:16 |  #13
JWright wrote in post #7313621 (external link)
If he is, and insists on using the grip, he may wish to weather seal the NOW non-weather sealed parts. DUH
moew!!!!!
dfek
Feb 12, 2009 18:35 |  #14
I know we've gotten a decent amount of snow here in Jersey in the past few weeks, but unless you're planning a trip to Antarctica or possibly an extended hike in the desert I think you'd be safe. Now taking photos while walking around in Camden that may be a different story, but then again it wouldn't be the weather sealing that you would have to worry about.
Seriously though, I just had my 5DII out in the light rain for about 15 mins. this morning and everything worked out well.
bacchanal
Feb 12, 2009 18:40 as a reply to  @ dfek's post |  #15
The only thing that really scares me is beer...that is about the most adverse precipitation I ever find myself shooting in.
12,259 views & 0 likes for this thread, 40 members have posted to it.
1032 guests, 112 members online
