Thread started 13 Feb 2009 (Friday) 11:25
40D + 100-400 + 1.5x TC problems
badams
Feb 13, 2009 11:25 |  #1
Last weekend I decided to use my 100-400 and 1.5x TC since the wind was blowing so hard there wasn't going to be any possible way to hold the 500. Anyways, back to the problem.
I couldn't get it to autofocus on anything. I was using AI Servo. At first I thought it was a lens problem, but I put it on the XT and it focused fine. Later when I got home, I put the 100-400 on the 40D (no TC) and it worked fine too.
So does the 40D not like the TC (non-reporting) when the 100-400 is attached? I used this combo all the time on the XT without a problem.
Everyday use: 7D2, 1.4x v3 Canon TC (sometimes the 2x v2 Canon TC), Canon 500mm f4 L IS USM; 6D, 24-105L
http://www.southernokp​hotography.com (external link)
ogre1231
Feb 13, 2009 11:27 |  #2
40d shouldn't autofocus with the tc and 1-4 on there. it's not supposed to work with autofocus on lenses with a max aperture of 5.6. I've heard about taping the pins, but i think that's the 30d and older models.
badams
Feb 17, 2009 09:45 |  #3
I shouldn't need to tape pins since this TC doesn't report.
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Feb 17, 2009 09:48 |  #4
Only 1D bodies can auto-focus at f/8... not much about reporting, but rather, the actual amount of light reaching the AF sensor.
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
Lowner
"I'm the original idiot"
Feb 17, 2009 10:26 as a reply to  @ ebann's post |  #5
badams,
I've read conflicting posts about whether different models do or don't work with converters. Some users insist that on certain models it's impossible while others claim thats nonsense.
All I know is that with my 30D, using a Kenko C-AF 1.4x PRO 300 DG I needed to tape three of the eleven pins for the 100-400 to AF. With the pins taped it AF's perfectly. Before I bought the PRO 300 I tried a cheaper Kenko 1.4x and did not need to tape any pins.
Maybe the difference between your 1.5x and my 1.4x makes a difference, I just don't know.
Richard
Don ­ Powell
Joined Nov 2005
Feb 17, 2009 11:36 as a reply to  @ Lowner's post |  #6
I have a 30D and I know that my Tamron-F 1.4x C AF1 MC4 will autofocus on my Canon 500mm f4.5 L. I just attached it to my Canon 100-400 L and it autofocused just fine.
I think that the more expensive teleconverters ( Pro ) models are the ones that fail to autofocus past f5.6.
I bough my Tamron 1.4x a long time ago, used, and I did not use it because I thought it would degrade the image too much. About a year ago I tried it on the 500 and was amazed how well it did. It has bailed me out several times since.
1,052 views & 0 likes for this thread, 5 members have posted to it.
1048 guests, 103 members online
