- White craft foam + silicone rubber band.
- Goal was to raise and spread direct, unbounced flash
- It bleeds a little to the ceiling
- probably does not have great evenness of coverage
4130 Member 94 posts Joined Oct 2008 More info | Feb 13, 2009 17:45 | #1
Looking for a carbon tripod and head capable of supporting a 5D body and 35 mm L
SYS Cream of the Crop More info | Feb 13, 2009 20:27 | #2 How about getting a black fun foam for covering the back side?
Feb 14, 2009 08:13 | #3 SYS wrote in post #7321118 How about getting a black fun foam for covering the back side? I have some black foam, but I didn't use it for this first trial pattern. Looking for a carbon tripod and head capable of supporting a 5D body and 35 mm L
SYS Cream of the Crop More info | Feb 14, 2009 10:17 | #4 The reason why I've always favored the following DIY foam diffuser-reflector (revised version of Chuck Gardner and others before him) is that I can control the forward or upward direction of the light. The "ceiling" of this DIY is designed to close all the way down or all the way up to vertical position. When it's all the way down, all the light goes forward (for no-bounce situations, such as outdoors or indoors without friendly walls or ceilings). When it's all the way up, most of the light goes upward (or sideward depending on the flash head swivel position) for bouncing purposes.
SYS Cream of the Crop More info | Feb 14, 2009 10:44 | #5 Another thing...
| Latest registered member is SteveeY 1699 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
